SNMP on IP Phones
Leonardo Santana
I know that the IP Phones does not support
https://supportforums.cisco.com/discussion/10697501/very-urgent-snmp-enable-ip-phone
The status is the same? The only to monitor is through CUCM SNMP?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
No it is not possible and I don't think it should be.
Think about a medium environment of 3000 phones and you need to poll each one for SNMP every 3 mins. The poller needs to be a supercomputer to handle the amount of processing in addition to licensing it.
Why anyone would need all of this while you can get the same output by polling this information from a single node which is CUCM.
