Softkey Call pickup not displaying on Cisco 78XX
akram.root
Level 4
Level 4
Hello all ,
I need your help please .
I have a problem on Cisco Ip phones 78XX can't display the softkey call pickup ,i applied the Softkey Template but not applied in these phones .
Best regards
Ratheesh Kumar
Hi there
There is an enhancement request in Cisco with 78XX, if the "Disable Speakerphone" checkbox is checked in the Phone Configuration page, this removed the Softkey options phone.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup64734
Also check this great solution from Maron Mahoney
https://community.cisco.com/t5/ip-telephony-and-phones/7841-issues-softkey-template/td-p/3357423
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
