10-03-2007 12:41 AM - edited 03-14-2019 11:51 PM
Hi there,
Just an easy one. I can't seem to find a way to change the Softkey Template for the 7936 Conference Phone in Call Manager 4.1(3).
I'm looking to remove the GrpPickup and Pickup keys, as they aren't relevant for our Conference Phones. However, there doesn't seem to be a way to do it like you can with 7960 IP Phones...
Can it actually be changed, or should I just live with those extra buttons?
Thanks!
David
Solved! Go to Solution.
10-03-2007 04:22 AM
Hi David,
I was just working on a thread recently that addressed this same question. The word from Cisco is that the Softkey Template for Models 7935 and 7936 Conference phones cannot be changed :(
Hope this helps! Sorry man,
Rob
10-03-2007 04:22 AM
Hi David,
Rob
10-03-2007 06:03 PM
Thanks for the information Rob!
This saves me a lot of time - Now I won't go around looking for a setting that doesn't exist.
It's not a big deal that those buttons stay there anyways...
David
10-03-2007 06:43 PM
Hi David,
You are most welcome :) If you are like me it seems like I spend a fair bit of time looking to fix things that are not fixable. One less thing to look at, so, on to the next I'm sure!
Take care,
Rob
