Softkey, where is it pulled from?
Marcin Brzeski
I would like to remove one soft button from the phone (7961) but both Device Profile and Phones have the Softkey Templates set to None.
How is the Softkey Template assigned to the phones globally and where to find it? We use CM 8.5.
Thanks!
Softkeys are assigned per device type, if its none then its taking the global value for the device type
Choose Device > Device Settings > Softkey Template
Click Add New.
For more info
Click Add New.
For more info
Hi Zekeria,
This is what I was looking for. Thanks a lot.
Marcin
My pleasure Marcin.
