03-30-2012 09:52 AM - edited 03-16-2019 10:23 AM
I wan to upgrade my CUCM from 8.6.1.20000-1 to 8.6.2.20000-2.
My question is Could be able to just upgrade the CUCM and not the UNITY Connection?
Im planning to the Unity upgrade later.
any recommendation will be great
thanks
Solved! Go to Solution.
03-30-2012 09:54 AM
Yes, you can. I presume your CUC is also 8.6.
GP.
Pls rate helpful posts by clicking on the stars below the post !!
03-30-2012 09:57 AM
Depends, if you're talking about a CUCMBE 5K the answer is no, you upgrade the whole system.
If they're standalone installs, then yes.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-30-2012 10:03 AM
CUCM 8.6.2 is compatible with CUEAC/CUBAC 8.6.2.11. Refer page 12 of following release notes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUBDAC_Rel_Note8_6_2_11.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUEAC_Rel_Note8_6_2_11.pdf
GP.
Pls rate helpful posts !!
03-30-2012 09:54 AM
GP.
03-30-2012 09:57 AM
my unity Connection is
Version 8.6.1.20000-109
03-30-2012 09:58 AM
Could you provide the documentation that show the CUCM could be a higher version than the unity COnnection in my case
03-30-2012 10:08 AM
Sure, here all you need to ensure is the compatibility between CUCM & CUC version. Which is documented clearly here http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html#wp38791
CUCM & CUC compatibility is very simple.
GP.
Pls rate all helpful posts !!
03-30-2012 10:09 AM
thanks
03-30-2012 09:55 AM
The reason im doing this is because Im
Installing Call Manager version 8.6.2.20000-2 (to fix the CDR Database issue) but it breaks CUEAC "System Version: 8.6.1.9" (Administration Version: 8.6.1.158) |
what would be the version for the CUEAC and for the CUBAC client that works with the cucm
8.6.2.20000-2. that im looking to upgrade?
thanks once again!
03-30-2012 10:03 AM
GP.
03-30-2012 09:57 AM
java
03-30-2012 10:00 AM
I got 1 CUCM and 1 Unity connection ( no clusters )
where can I see if the im running
CUCMBE 5K ?
03-30-2012 10:11 AM
Hi Alberto,
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
Cheers!
Rob
03-30-2012 10:12 AM
