[SOLVED] CME 7.1 Local Directory
Does any one know how to enable the local directory on CME?
I have done the steps in the Instalation Guide, but no joy.
When i press the Directory button on the phone show
"Host not found"
Any clue?
8 Replies 8
Priyadarshini B.T
hi,
please check the below configuration are already present
Under telephony-service, add "service local-directory" command
Specify the "type 7941" under ephone ( or the phone type you are using, this is just an example )
Do a no create cnf-files, create cnf-files and reboot the phone.
and let me know how it goes.
Same problem
Host not found
send me the output of "show run"
Follows the sh run
Follows the sh run
hi Rafael,
Please configure the following in the telephony service:
directory {first-name-first | last-name-first}
no service local-directory
no create cnf-files
create cnf-files
reset the phones
after this please refer the link below as some steps has been missingin the configuration,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmedirs.html#wpmkr1011010
Solved the problem.
I configured a NTP server and put the
ip http command.
Problem solved.
Thanks  Priya for your support.
i am glad the issue got resolved.
have a great day
