08-09-2011 12:43 PM - edited 03-16-2019 06:22 AM
Does any one know how to enable the local directory on CME?
I have done the steps in the Instalation Guide, but no joy.
When i press the Directory button on the phone show
"Host not found"
Any clue?
08-09-2011 12:55 PM
hi,
please check the below configuration are already present
Under telephony-service, add "service local-directory" command Specify the "type 7941" under ephone ( or the phone type you are using, this is just an example ) Do a no create cnf-files, create cnf-files and reboot the phone.
and let me know how it goes.
08-09-2011 01:03 PM
Same problem
Host not found
08-09-2011 01:08 PM
send me the output of "show run"
08-09-2011 03:22 PM
08-09-2011 03:22 PM
08-10-2011 04:53 AM
hi Rafael,
Please configure the following in the telephony service: directory {first-name-first | last-name-first} no service local-directory no create cnf-files create cnf-files
reset the phones
after this please refer the link below as some steps has been missingin the configuration,
08-10-2011 05:39 AM
Solved the problem.
I configured a NTP server and put the
ip http command.
Problem solved.
Thanks Priya for your support.
08-10-2011 05:43 AM
i am glad the issue got resolved.
have a great day
