Some outbound 800 numbers ring busy
Derek.Leach
I have an issue where some random outbound 800 numbers ring busy.  I have CUCU and PRI circuit.  When I run debug isdn q931 I will get the following for the 800 that will give a busy signal, but another 800 number works just fine. The problem numbers work fine outside our phone system.  My guess it is a routing problem with PRI carrier but not sure where else to look to prove one way or another.
Any feedback would be appreciated!!
Output that 800 not working – Cause i = 0x8091 - User busy
022331: Mar 25 10:17:08.644 CDT: ISDN Se0/0/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=87 nr=84
022332: Mar 25 10:17:08.644 CDT: ISDN Se0/0/0:23 Q931: SETUP pd = 8  callref = 0x015D
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x0081, '7001'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x88, '18009220204'
                Plan:National, Type:Unknown
022333: Mar 25 10:17:08.660 CDT: ISDN Se0/0/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=88
022334: Mar 25 10:17:09.248 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=84 nr=88
022335: Mar 25 10:17:09.248 CDT: ISDN Se0/0/0:23 Q931: CALL_PROC pd = 8  callref = 0x815D
022336: Mar 25 10:17:09.248 CDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=85
022337: Mar 25 10:17:11.268 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=85 nr=88
022338: Mar 25 10:17:11.268 CDT: ISDN Se0/0/0:23 Q931: DISCONNECT pd = 8  callref = 0x815D
022339: Mar 25 10:17:11.268 CDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=86
022340: Mar 25 10:17:11.288 CDT: ISDN Se0/0/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=88 nr=86
022341: Mar 25 10:17:11.288 CDT: ISDN Se0/0/0:23 Q931: RELEASE pd = 8  callref = 0x015D
022342: Mar 25 10:17:11.296 CDT: ISDN Se0/0/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=89
022343: Mar 25 10:17:11.316 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=86 nr=89
022344: Mar 25 10:17:11.316 CDT: ISDN Se0/0/0:23 Q931: RELEASE_COMP pd = 8  callref = 0x815D
022345: Mar 25 10:17:11.316 CDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=87
Output from working 800 number
022349: Mar 25 10:17:46.996 CDT: ISDN Se0/0/0:23 Q931: SETUP pd = 8  callref = 0x015E
                Standard = CCITT
        Called Party Number i = 0x88, '18004663337'
022350: Mar 25 10:17:47.016 CDT: ISDN Se0/0/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=90
022351: Mar 25 10:17:47.640 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=87 nr=90
022352: Mar 25 10:17:47.640 CDT: ISDN Se0/0/0:23 Q931: CALL_PROC pd = 8  callref = 0x815E
022353: Mar 25 10:17:47.640 CDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=88
022354: Mar 25 10:17:48.920 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=88 nr=90
022355: Mar 25 10:17:48.920 CDT: ISDN Se0/0/0:23 Q931: PROGRESS pd = 8  callref = 0x815E
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
022356: Mar 25 10:17:48.920 CDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=89
022357: Mar 25 10:17:49.944 CDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=89 nr=90
022358: Mar 25 10:17:49.944 CDT: ISDN Se0/0/0:23 Q931: ALERTING pd = 8  callref = 0x815E
0 Replies 0
