Sound card & VM & BE600
Yong Peng
Greeting!
I am making a LAB.
I am trying to run a VM on BE600, then, install softphone on the VM.
The problem is there is no a sound card on the VM, and the softphone can't be installed on the VM.
is there a way to install a virtual sound card on the VM?
can the softphone ring?
Thanks in advance!
Chris Deren
What OS did you install for the client? If the server you are installing it on has a sound car you should be able to use it in VM.
Chris
Thanks for your reply.
The server doesn't have a sound card.
I am trying to run winXP VM on ther server, then, install softphone on the winXP.
finally, I will use remote desktop to connect to the XP.
can softphone ring?
Hi ,
You can visit the site http://www.e2esoft.cn/vsc/ .They have got Virtual Sound Card.
May this help you.
regds,
aman
