sql database size cucm 4.3 -urgent help req-
SHAIHAN JAFFREY
Dear,
Please let me know step by step to check SQL database size in cucm 4.3
regards
Aaron Harrison
Go into SQL Enterprise Manager.
Click on the server, then go into databases and you should see a CCMxxx database. Right click on it and select Properties.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
