09-21-2011 03:08 PM - edited 03-16-2019 07:07 AM
I am trying to write sql command to get the list of MAC addresses and Phone numbers associated with a device pool. I can do this from CCM admin pages but when there are multiple entries I hve to search individually.
Is there any sql query to run using <run sql select >on ssh cli ?. I am using following query
:run sql select d.name , e.name from device d, devicepool e where d.fkdevicepool=e.pkid where d.name like "SEP%" I get the list of device name and device pool
This gives me devicename,devicepool . I am need to link Phone numbers to these .
Which table has phone numbers?. devicenumplan ?. how do I link device table and devicenumplan?
Solved! Go to Solution.
09-21-2011 03:27 PM
run sql SELECT device.name, devicepool.name, dnorpattern FROM device, devicepool, devicenumplanmap, numplan WHERE device.fkdevicepool=devicepool.pkid AND numplan.pkid=devicenumplanmap.fknumplan AND device.pkid=devicenumplanmap.fkdevice AND devicepool.name LIKE "FOO"
(Note: SEP% will only get you VoIP handsets. ATAs, VG224s, etc won't be listed)
GTG
09-21-2011 03:27 PM
GTG
