SRST configuration without CME
Knightvoice_2
We are looking to implement SRST without CME. We are running UCM 7.1.3. Is there a specific version that needs to be installed on the router? Plan on using a 2800 series router.
Thanks!
Chris
Jaime Valencia
Yes, depending on which SRST version you want to use:
Compatibility Information
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2169/products_device_support_tables_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks java.
i am not able to view that page. Can any version of SRST be used? I know there are firmware compatibility issues with the phones and right now 7.1 looks like the one that my firmware is compatible with.
Thanks!
Remove the "partner" word from the link
I keep forgetting to do this when I paste them too.
Alex
Regards, Alex. Please rate useful posts.
