TAMB2 and FXS
cowetacoit
We currently have some older TAMBs connected to an FXS port of a router, without having to use a power supply. We can dial the DN of the FXS and get a tone from the TAMB and then start a page. When we're done with the page we can hang up and the pages ends. Bogen stopped making the TAMB and replaced it with a TAMB2. We set up the TAMB2 and FXS exactly like our other configuration but the TAMB2 requires a 24v power supply. When we connect the power supply and make a test page it works but when we hang up the TAMB2 doesn't stop the page. We get a busy tone untill we unplug it. Does anyone know how to get around this? We also orignally started using ATA186/187 but could never make it work.
Thanks!
6 Replies 6
acampbell
Have look at this link.
May be a "disconnect"option here will fix it
http://www.cisco.com/en/US/partner/docs/ios/voice/fxs/configuration/guide/fxsbasic.html#wp1019397
Alex
Regards, Alex. Please rate useful posts.
i'm unable to view that. Looks like that is for channel partners only.
Rob Huffman
Hi there,
Just to add a note to the good tips from Alex (+5 )
Here is the related TAMB@ info for FXS disconnect;
Station Port Interfacing:
The TAMB2 answers the station port after it detects high
voltage (90V) ring on the line. The unit can be set to answer
the call immediately or after the end of the first ring burst. Once
answered, the unit provides an announcement tone and connects
the telephone line to the paging amplifier through an isolation
transformer. The announcement tone can be set to be
heard only at the paging phone or at both the phone and over
the paging system. The TAMB2 allows bi-directional audio,
both to and from the paging equipment (in the case of talkback
paging equipment). Since the TAMB2 cannot directly
determine the state of the calling partyʼs phone, it must use
indirect methods to determine when to disconnect. Disconnection
of the TAMB2 from the call is controlled through 3
methods. 1) A default timer will drop the call after a preset
amount of time has elapsed (1-200 seconds), 2) A VOX timer
will drop the call after it detects no audio for a preset amount
of time (1-11 seconds), 3) The unit will immediately drop the
line if it detects a CPC pulse (break in loop current) from the
PBX/CO port. Any of these disconnection methods can be inhibited,
however at least one must be enabled to ensure that
the TAMB2 will disconnect.
Cheers!
Rob
Rob Huffman
Cool, thanks guys. I'll give this a try!
Wow Rob.
You are on the ball as usual. +5
I must try to remmber to leave out the "partner" in my links.
Alex
