12-14-2016 09:26 PM - edited 03-17-2019 08:57 AM
Can anyone tell me is SRST available in Cisco's VG gateway?Do it need any license? If Yes then how we can get this feature? If it's, then is it available for both Analog and IP Phone through VG gateway? Do ISR gateway can provide both IP and Analog Phones?
12-14-2016 11:39 PM
Hi Anand,
For platform and endpoint compatibility with SRST please check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs115spc.html
For configuring the same please use the SRST admin guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide.html
Manish
12-14-2016 11:45 PM
Thanks Manish!
I want to check it for Analog device.I know ISR gateway support it according to their capacity and sizing. Could you please send me the same for VG gateway viz. 224, 310, 320 and 350.
12-14-2016 11:51 PM
Check this specific link related to analog phones/ports config for SRST
http://www.cisco.com/c/en/us/td/docs/ios/voice/fxs/configuration/guide/15_1/fxs_15_1_cg_book/fxssrst.html
Manish
