SRST incoming call fail on FXO Port
Mario Musquiz
Hi all
im using cisco 2901 has a MGCP Gateway whit FXO ports on a remote branch office.
When the Gateway is connected to the CUCM all works fine but when the Gateway disconnects from the CUCM it goes into SRST mode:
In SRST Mode the outgoing calls works fine.
The problem is when there is a incoming call  on SRST mode :  the external incoming call ring one time and after that the call is connected, but with silent, the extension won't ring and the FXO ports stays on until the cable is unpulg.
Using debug voip ccapi i see the incoming calls are getting into the (dial-peer voice 999010 pots) ignoring the (connection plar 216) on each port.
If i delete the (dial-peers voice 999010 pots) when on SRST Mode then all the incoming calls works fine, but when the connection to the CUCM is establish the dial-peers gets back on.
what am i missing here ?
Thanks in advance.
Here is my configuration:
trunk group TELNOR_GROUP
hunt-scheme longest-idle
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
voice hunt-group 1 parallel
list 216,215,214,213
timeout 20
pilot 280
voice translation-rule 1
rule 1 /^8/ //
voice translation-profile OutgoingProfile_1
translate called 1
voice-card 0
dsp services dspfarm
application
global
  service alternate default
ip tftp source-interface Vlan100
ip ssh version 1
interface Loopback0
ip address 10.2.10.2 255.255.255.252
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Vlan100
ip address 10.2.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.2.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 20 remark CCP_ACL Category=1
access-list 20 permit 192.168.2.0 0.0.0.255
access-list 20 permit 10.2.2.0 0.0.0.255
access-list 20 permit 192.168.0.0 0.0.0.255
access-list 20 permit 10.242.2.0 0.0.0.255
access-list 20 permit 10.1.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=2
access-list 100 deny   ip 10.2.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 deny   ip 10.2.10.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 100 deny   ip 10.2.10.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 100 deny   ip 10.2.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 deny   ip 10.2.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 deny   ip 10.2.2.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 100 deny   ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 100 deny   ip 10.2.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 deny   ip 192.168.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 deny   ip 192.168.2.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 100 deny   ip 192.168.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 100 deny   ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 2000 remark CCP_ACL Category=4
access-list 2000 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 2000 permit ip 192.168.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 2000 permit ip 192.168.2.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 2000 permit ip 192.168.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 2000 permit ip 10.2.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 2000 permit ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 2000 permit ip 10.2.2.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 2000 permit ip 10.2.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 2000 permit ip 10.2.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 2000 permit ip 10.2.10.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 2000 permit ip 10.2.10.0 0.0.0.255 10.242.2.0 0.0.0.255
access-list 2000 permit ip 10.2.10.0 0.0.0.255 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address 100
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
ring frequency 20
voice-port 0/1/0
trunk-group TELNOR_GROUP
supervisory disconnect dualtone mid-call
no battery-reversal
cptone MX
timeouts call-disconnect 1
timeouts wait-release 3
timing hookflash-out 50
connection plar 216
description TELNOR_0
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone MX
connection plar 216
description TELNOR_1
caller-id enable
voice-port 0/1/2
cptone MX
caller-id enable
voice-port 0/1/3
cptone MX
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
ccm-manager shut-backhaul-interfaces
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.1.2
ccm-manager config
mgcp
mgcp call-agent 10.1.1.2 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface Vlan100
mgcp bind media source-interface Vlan100
mgcp profile default
sccp local Vlan100
sccp
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 1 pots
trunkgroup TELNOR_GROUP
description International
translation-profile outgoing OutgoingProfile_1
destination-pattern 800T
forward-digits all
dial-peer voice 2 pots
description National_Cell
destination-pattern 8045..........
forward-digits all
dial-peer voice 3 pots
destination-pattern 801..........
forward-digits all
dial-peer voice 4 pots
description Local_Cell
destination-pattern 8044686.......
forward-digits all
dial-peer voice 5 pots
description Local
destination-pattern 8.......
forward-digits all
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.2.2.1 port 2000
max-ephones 12
max-dn 8 dual-line
system message primary SRST
date-format dd-mm-yy
Hi Mario
1- I didnot notice ccm-manager fallback-mgcp on your configuation , pleae check. This is manadatory .
2-no need for inbound dial-peer.
Please rate all useful information
9 Replies 9
islam.kamal
Level 10
Level 10
Hi Mario
Can you find the below?.
1-configure terminal
application
global
  end
2-Test
If this not help , please use plar-opx instead of plar
Hi, i do have the (service alternate default)
I try whit the (connection plar opx) and the (connection plar opx immediate) and i still get the same issue.
Do i need to create a dial-peer for incoming calls in SRST mode ? if so, how can i foward a call to a extension in a dial-peer ?
Regards.
Hi Mario
Can you share the following
debug mgcp pack
debug vpm sig
debug voip ccapi inout
hi here is a debug of a call in SRST Mode
.Feb 23 20:27:41.028: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
.Feb 23 20:27:41.028: htsp_timer - 125 msec
.Feb 23 20:27:41.156: htsp_process_event: [0/1/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
.Feb 23 20:27:41.156: htsp_timer - 10000 msec
.Feb 23 20:27:41.156: htsp_timer3 - 5600 msec
.Feb 23 20:27:41.156: [0/1/1] htsp_start_caller_id_rx:BELLCORE
.Feb 23 20:27:41.156: htsp_start_caller_id_rx create dsp_stream_manager
.Feb 23 20:27:41.156: [0/1/1] htsp_dsm_create_success  returns 1
.Feb 23 20:27:41.464: htsp_process_event: [0/1/1, FXOLS_RINGING, E_DSP_SIG_0100]
.Feb 23 20:27:41.464: fxols_ringing_not
.Feb 23 20:27:41.464: htsp_timer_stop
.Feb 23 20:27:41.464: htsp_timer - 10000 msec
.Feb 23 20:27:43.116: [0/1/1] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
.Feb 23 20:27:43.116: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
.Feb 23 20:27:43.116: htsp_timer_stop
.Feb 23 20:27:43.116: htsp_timer_stop3
.Feb 23 20:27:43.116: [0/1/1] htsp_stop_caller_id_rx. message length 25htsp_setup_ind
.Feb 23 20:27:43.116: [0/1/1] get_fxo_caller_id:Caller ID received. Message type=128 length=25 checksum=AD
.Feb 23 20:27:43.116: [0/1/1] Caller ID String 80 16 01 08 30 32 32 33 31 32 32 37 02 0A 36 36 34 33 36 38 37 34 32 37 AD
.Feb 23 20:27:43.116: [0/1/1] get_fxo_caller_id calling num=*** calling name= calling time=02/23 12:27
.Feb 23 20:27:43.120: fxols_callerid_done: call being answered
.Feb 23 20:27:43.120: //-1/C854B5C58039/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=***
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=216
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
.Feb 23 20:27:43.120: //-1/C854B5C58039/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x89BB62B8, Call Info(
   Calling Number=***,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=216(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=999011, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=TELNOR_GROUP, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
.Feb 23 20:27:43.120: //-1/C854B5C58039/CCAPI/ccCheckClipClir:
   In: Calling Number=***(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=***(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
.Feb 23 20:27:43.124: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
.Feb 23 20:27:43.124: :cc_get_feature_vsa malloc success
.Feb 23 20:27:43.124:  cc_get_feature_vsa count is 1
.Feb 23 20:27:43.124: :FEATURE_VSA attributes are: feature_name:0,feature_time:2351182240,feature_id:16
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=***(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=216(TON=Unknown, NPI=Unknown))
.Feb 23 20:27:43.124: [0/1/1] htsp_dsm_close_done
.Feb 23 20:27:43.124: htsp_process_event: [0/1/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
.Feb 23 20:27:43.124: fxols_wait_setup_ack:
.Feb 23 20:27:43.124: [0/1/1] set signal state = 0xC timestamp = 0fxols_check_auto_call
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/cc_process_call_setup_ind:
   Event=0x89B666A0
.Feb 23 20:27:43.124: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 216
   >>>>CCAPI handed cid 20 with tag 999011 to app "MGCPAPP"
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/ccCallSetContext:
   Context=0x8AE819A8
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/ccCallSetupAck:
   Call Id=20
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
.Feb 23 20:27:43.124: //20/C854B5C58039/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
.Feb 23 20:27:43.128: //20/C854B5C58039/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
.Feb 23 20:27:43.128: MGCP Packet sent to 10.1.1.2:2427--->
NTFY 841693232 aaln/S0/SU1/1@GW-MXI MGCP 0.1
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:43.128: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_SETUP_ACK]
.Feb 23 20:27:43.128: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
.Feb 23 20:27:43.128: htsp_timer_stop
.Feb 23 20:27:43.396: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
.Feb 23 20:27:43.396: htsp_timer_stop2
.Feb 23 20:27:43.632: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:44.652: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:46.672: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:50.693: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:54.713: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:27:58.733: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
.Feb 23 20:28:02.753: MGCP Packet sent to 10.1.1.2:2427--->
N: ca@10.1.1.2:2427
X: 0
O: L/hd
Mario..
You need ccm-manager fallback-mgcp, this is different from call-manager-fallback
RemoteSite# configure terminal
RemoteSite(config)# ccm-manager fallback-mgcp
RemoteSite(config)# application
RemoteSite(config - app)# global
RemoteSite(config - app -global)# service alternate default
RemoteSite(config - app -global)# end
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi i try it but still the same issue.
Here is a full configuration
! Last configuration change at 12:22:19 Pacific Sun Feb 23 2014 by
version 15.1
hostname ***
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone Pacific -8 0
clock summer-time Pacific date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.9
ip dhcp excluded-address 192.168.2.251 192.168.2.254
ip dhcp excluded-address 10.2.2.1 10.2.2.9
ip dhcp excluded-address 10.2.2.251 10.2.2.254
ip dhcp pool data
import all
network 192.168.2.0 255.255.255.0
dns-server 192.168.2.1
default-router 192.168.2.1
ip dhcp pool voice
import all
network 10.2.2.0 255.255.255.0
option 150 ip 10.1.1.2
default-router 10.2.2.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ddns update method ccp_ddns1
HTTP
  add ***
  remove ***
no ipv6 cef
voice class codec 1
timeout 20
pilot 280
rule 1 /^8/ //
translate called 1
voice-card 0
application
global
license udi pid C1861E-UC-4FXO-K9
username ***
username ***
ip ssh version 1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key *** address ***
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to***
set peer ***
set transform-set ESP-3DES-SHA
match address 2000
interface Loopback0
interface FastEthernet0/0
description WAN$ETH-WAN$
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Integrated-Service-Engine0/0
description CUE
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.2.10.1 255.255.255.252
service-module ip default-gateway 10.2.10.2
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
interface Dialer0
ip ddns update ***
ip ddns update ccp_ddns1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ***
ppp chap password 0 ***
ppp pap sent-username *** password 0 ***
ip http server
ip dns server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
ring frequency 20
voice-port 0/1/0
no battery-reversal
cptone MX
connection plar 216
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone MX
connection plar 216
caller-id enable
voice-port 0/1/2
cptone MX
caller-id enable
voice-port 0/1/3
cptone MX
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
ccm-manager config
mgcp
mgcp sdp simple
sccp local Vlan100
sccp
service mgcpapp
port 0/1/0
service mgcpapp
port 0/1/1
service mgcpapp
port 0/0/0
service mgcpapp
port 0/0/1
service mgcpapp
port 0/0/2
service mgcpapp
port 0/0/3
service mgcpapp
port 0/1/2
service mgcpapp
port 0/1/3
forward-digits all
forward-digits all
forward-digits all
forward-digits all
description Local
forward-digits all
max-ephones 12
max-dn 8 dual-line
default-destination 216
line con 0
session-timeout 5
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
session-timeout 5
login local
transport input all
line vty 5
session-timeout 5
login
transport input all
ntp update-calendar
ntp server 192.168.0.254 prefer source Vlan1
end
HI Mario
The above configuration is differnent from the 1st configuation which you posted firstly .
*ccm-manger mgcp    is missing above .
If you need to allow fallback , just type no mgcp on the config mode.
Can you check again your configuration and share the latest?.
show ccm-manager                               after fallback
Please rate all your useful information
Hi sorry i was playing whit the configuration when i did the "show running"
now is working
First i had
ccm-manager mgcp
Then change it to
ccm-manager mgcp
Thanks.
