SRST Integration with Unity Connection
waqas sardar
Hi All
Voice Gateway is configured as mgcp .
Issue is voicemail is not working in case on fallback. Pls see the below configuration :
I have CUCM 10.5 and Unity connection 10.5. Attached are the Unity snapshoots
no aaa new-model
clock timezone GMT 4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip dhcp pool ipphones
 network 192.168.210.0 255.255.255.0
 default-router 192.168.210.1
 option 150 ip 192.168.210.10
 domain-name wr
ip domain name NLJcapital.kwi
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 modem passthrough nse codec g711ulaw
 h323
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
  no silent-discard untrusted
voice register global
 mode srst
 timeouts interdigit 7
 max-dn 10
 max-pool 40
voice translation-rule 7
 rule 1 /^2/ /043652/
voice translation-rule 9
 rule 1 /^1/ /91/
 rule 2 /^2/ /902/
 rule 3 /^3/ /903/
 rule 4 /^4/ /904/
 rule 5 /^5/ /905/
 rule 6 /^6/ /906/
 rule 7 /^7/ /907/
 rule 8 /^8/ /98/
 rule 9 /^9/ /9009/
 rule 10 /^0/ /90/
voice translation-rule 10
 rule 1 /^1/ /83041/
 rule 2 /^2/ /83042/
 rule 3 /^3/ /83043/
 rule 4 /^4/ /83044/
 rule 5 /^5/ /83045/
 rule 6 /^6/ /83046/
 rule 7 /^7/ /83047/
 rule 8 /^8/ /83048/
 rule 9 /^9/ /83049/
 rule 10 /^0/ /83040/
voice translation-rule 11
 rule 1 /^1/ /83651/
 rule 2 /^2/ /83652/
 rule 3 /^3/ /83653/
 rule 4 /^4/ /83654/
 rule 5 /^5/ /83655/
 rule 6 /^6/ /83656/
 rule 7 /^7/ /83657/
 rule 8 /^8/ /83658/
 rule 9 /^9/ /83659/
 rule 10 /^0/ /83650/
voice translation-profile Add9
 translate calling 9
voice translation-profile CALL-KWT
 translate calling 10
voice translation-profile CALL-NLJBranches
voice translation-profile change_calling
 translate calling 7
application
 global
  service alternate default
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31 service mgcp
ip ssh authentication-retries 5
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address 192.168.210.11 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn outgoing display-ie
 isdn outgoing ie redirecting-number
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.210.1
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp
mgcp call-agent 192.168.210.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.210.10 identifier 1 priority 1 version 7.0
sccp ccm 192.168.210.11 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register HQ-CONF
 associate profile 2 register HQ-XCODE
ccm-manager music-on-hold
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config
dspfarm profile 2 transcode universal
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8
 codec g729r8
 codec ilbc
 codec pass-through
 maximum sessions 3
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec ilbc
 maximum sessions 2
dial-peer voice 1 pots
 translation-profile incoming Add9
 preference 7
 destination-pattern 9.T
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
dial-peer voice 101 pots
 translation-profile outgoing change_calling
 preference 3
 destination-pattern 9(050.......)
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 progress_ind connect enable 8
 translate-outgoing calling 7
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 102 pots
 preference 2
 destination-pattern 9([2,3,4,5]......)
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 103 pots
 preference 1
 destination-pattern 9(0[2,3,6,7].......)
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 104 pots
 destination-pattern 9T
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 165 pots
 preference 3
 destination-pattern 9(055.......)
 direct-inward-dial
 port 0/0/0:15
num-exp 2800 2824
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 192.168.210.11 port 2000
 max-ephones 75
 max-dn 152 dual-line
 keepalive 20
 voicemail 5000
 call-forward busy 5000
 call-forward noan 5000 timeout 20
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input all
scheduler allocate 20000 1000
ntp master 2
end
NLJ-VG#
6 Replies 6
Jaime Valencia
I don't see any DP to match your VM config.
java
if this helps, please rate
Hi Jaime
Following configuration is not enough for voimail in fall back ?
 max-ephones 75
 keepalive 20
 voicemail 5000
Actually i follow the link
https://supportforums.cisco.com/discussion/10912606/srst-unity-connection-configuration
OK, then I suggest you review it again, because it clearly shows they have a matching DP for the target they configured for VM and call forward, which you don't have.
That would be assuming you're going to send calls over the PSTN to reach CUC, I'm assuming that's what you're doing, correct???
java
Jaime Valencia
Both CUCM Unity Connection and Voice gateway (srst )a re on the HQ site. I want voice mail acces for phones in SRST & MGCP fallback.
  • Is it possible  ?
  • Hunt Pilot 5000 is a not DID number .
  • Telephone-service command is not working as gateway is configured with Call-manager-Fallback.
Pls explain with rest of the configuration
Hi Waqas,
The Call-manager-fallback exclusively works for SCCP Phones, are your phones SCCP only or mix of SCCP and SIP?
Wilson Samuel
All phones are SCCP and ATA 190.
