03-13-2013 09:59 AM - edited 03-16-2019 04:14 PM
Hello guys!
Currently I'm configuring SRST on a Cisco 2921 in conjunction with a CUCM8.6 (BE6000). When testing SRST, the phones show "MODE SRST", some pick up dial tone, some not, and on phones with dialtone phone calls did not progress. On the Cisco 2921 the debug ccapi all did not show nothing when attempting calls during the SRST test. It appears to me like phones were unable to register with the Voice Gateway (Cisco 2921). Below is the partial SRST config of Voice Gateway. My questions are the following:
1. Does it is neccesary to configure manually the ephones and directory numbers in the Cisco 2921 or phones will be allocated by the router automatically?
2. How to determine the SRST versipon currently running on Cisco 2921? Phones are 7940, 7960 and 7912.
3. On dialpeers (both voip and pots) it is necesary to enable the service mgcpapp in order to permit SRST calls to flow through the dialpeer?
4. Please reviw the SRST config below and if I'm missing something let me know!
Thanks in advanced guys, appreciate your help.
Partial SRST configuration:
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.200.54.3
ccm-manager config
mgcp
mgcp call-agent 10.200.54.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp af31 media
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.54
mgcp bind media source-interface GigabitEthernet0/0.54
mgcp profile default
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.200.54.1 port 2000
max-ephones 25
max-dn 25
system message primary Operating in mode SRST
keepalive 10
default-destination 4123
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.200.54.3 10.32.84.54
Solved! Go to Solution.
03-14-2013 11:37 AM
For POTS lines I prefer "debug vpm all"
Myself, I'd have the following two debugs running:
debug voip dialpeer all
debug vpm all
As Ajay pointed out the dialpeer debug will show you which dial-peer was matched. The vpm (Voice Port Module) debug will show you what goes out the FXO port and also what digits were dialed.
-Steven
Please help us make the communities better. Rate helpful posts!
03-15-2013 10:35 AM
Hello guys!
I tested. phones registered, calls internally worked, bot no inbound/outbound worked. No outgoing dialpeer was matched. Below the debug of an incoming call:
047523: Mar 15 17:37:23.129 UTC: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
047524: Mar 15 17:37:23.129 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
047525: Mar 15 17:37:23.129 UTC: htsp_timer - 125 msec
047526: Mar 15 17:37:23.257 UTC: htsp_process_event: [0/0/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
047527: Mar 15 17:37:23.257 UTC: htsp_timer - 10000 msec
047528: Mar 15 17:37:23.257 UTC: htsp_timer3 - 5600 msec
047529: Mar 15 17:37:23.257 UTC: [0/0/0] htsp_start_caller_id_rx:BELLCORE
047530: Mar 15 17:37:23.257 UTC: //-1//dsp_stream_mgr_create: .
047531: Mar 15 17:37:23.257 UTC: //-1//set_echo_canceller_data: echo_cancel: 0
047532: Mar 15 17:37:23.257 UTC: //-1//set_echo_canceller_data: echo_flags: 38, echo_len: 1024
047533: Mar 15 17:37:23.257 UTC: htsp_start_caller_id_rx create dsp_stream_manager
047534: Mar 15 17:37:23.257 UTC: //-1//dsp_stream_mgr_set_dsp_allocated: .
047535: Mar 15 17:37:23.257 UTC: //-1//dsp_stream_mgr_implement_feature:
047536: Mar 15 17:37:23.257 UTC: dsp_stream_mgr_implement_feature: feature id = 7
047537: Mar 15 17:37:23.257 UTC: //-1//dsmp_dsmapi_reserve_resource_cb: .
047538: Mar 15 17:37:23.257 UTC: [0/0/0] htsp_dsm_create_success returns 1
047539: Mar 15 17:37:23.257 UTC: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
047540: Mar 15 17:37:24.909 UTC: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
047541: Mar 15 17:37:24.909 UTC: fxols_ringing_not
047542: Mar 15 17:37:24.909 UTC: htsp_timer_stop
047543: Mar 15 17:37:24.909 UTC: htsp_timer - 10000 msec
047544: Mar 15 17:37:28.857 UTC: htsp_process_event: [0/0/0, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
047545: Mar 15 17:37:28.857 UTC: htsp_timer_stop3
047546: Mar 15 17:37:29.129 UTC: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0000]
047547: Mar 15 17:37:30.913 UTC: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
047548: Mar 15 17:37:30.913 UTC: fxols_ringing_not
047549: Mar 15 17:37:30.913 UTC: htsp_timer_stop
047550: Mar 15 17:37:30.913 UTC: htsp_timer_stop3
047551: Mar 15 17:37:30.913 UTC: //-1//dsp_stream_mgr_destroy: .
047552: Mar 15 17:37:30.913 UTC: //-1//dsm_delete_all_streams: .
047553: Mar 15 17:37:30.913 UTC: //-1//dsmapi_accept_modem_passthrough_session: : dmgr: 2BD8E910, active sessions 0, max sessions: 16 rejected sessions till now: 0
047554: Mar 15 17:37:30.913 UTC: [0/0/0] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
047555: Mar 15 17:37:30.913 UTC: [0/0/0] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
047556: Mar 15 17:37:30.913 UTC: [0/0/0] get_local_station_id calling num= calling name= calling time=03/15 17:37 orig called=
047557: Mar 15 17:37:30.913 UTC: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 0, 0, 0, 65535)
047558: Mar 15 17:37:30.913 UTC: TGRM: Calling vtsp_tsp_call_setup_ind().
047559: Mar 15 17:37:30.913 UTC: //-1/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x30FF6240,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
047560: Mar 15 17:37:30.913 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_PORT;
047561: Mar 15 17:37:30.913 UTC: //-1/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=999000
047562: Mar 15 17:37:30.913 UTC: //-1/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
047563: Mar 15 17:37:30.913 UTC: //-1/dpAssociateIncomingPeerSPI:exit@6564
047564: Mar 15 17:37:30.913 UTC: flex_dsprm_close_cleanup
047565: Mar 15 17:37:30.913 UTC: //-1//dsmp_dsmapi_reserve_resource_cb: .
047566: Mar 15 17:37:30.913 UTC: [0/0/0] htsp_dsm_close_done
047567: Mar 15 17:37:30.913 UTC: htsp_process_event: [0/0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
047568: Mar 15 17:37:30.913 UTC: fxols_wait_setup_ack:
047569: Mar 15 17:37:30.913 UTC: [0/0/0] set signal state = 0xC timestamp = 0
047570: Mar 15 17:37:30.913 UTC: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0xC timestamp=0x0fxols_check_auto_call
047571: Mar 15 17:37:30.913 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=6123, Peer Info Type=DIALPEER_INFO_SPEECH
047572: Mar 15 17:37:30.913 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=6123
047573: Mar 15 17:37:30.913 UTC: //-1/dpMatchCore:
Dial String=6123, Expanded String=6123, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
047574: Mar 15 17:37:30.913 UTC: //-1/dpMatchCore:
Result=-1
047575: Mar 15 17:37:30.913 UTC: //-1/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
047576: Mar 15 17:37:30.913 UTC: //-1/dpMatchSafModulePlugin:
dialstring=6123, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
047577: Mar 15 17:37:30.913 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047578: Mar 15 17:37:30.913 UTC: %CALL_CONTROL-6-APP_NOT_FOUND: Application mgcpapp in dial-peer 999000 not found. Handing callid 6627 to the alternate app Default.
047579: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047580: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047581: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047582: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047583: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047584: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
047585: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047586: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047587: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047588: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047589: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047590: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047591: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
047592: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047593: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
Calling Number=6123, Called Number=6123, Peer Info Type=DIALPEER_INFO_SPEECH
047594: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047595: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Dial String=6123, Expanded String=6123, Calling Number=6123T
047596: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047597: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047598: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
047599: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047600: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
Calling Number=6123, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
047601: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=6123
047602: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
047603: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Dial String=, Expanded String=, Calling Number=6123T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
047604: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047605: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:exit@5985
047606: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=6123
047607: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:
047608: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047609: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047610: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:exit@5985
047611: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
047612: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
047613: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeer:exit@6613
047614: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
047615: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
047616: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:
047617: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047618: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047619: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:exit@5985
047620: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
047621: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:
047622: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047623: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047624: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeertype:exit@5985
047625: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeerCore:
047626: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
047627: Mar 15 17:37:30.917 UTC: //-1/dpAssociateIncomingPeer:exit@6613
047628: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047629: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047630: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047631: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047632: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047633: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
047634: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047635: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047636: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047637: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
047638: Mar 15 17:37:30.917 UTC: //-1/dpMatchCore:
Result=-1
047639: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersCore:
047640: Mar 15 17:37:30.917 UTC: //-1/dpMatchSafModulePlugin:
dialstring=6123, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
047641: Mar 15 17:37:30.917 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
047642: Mar 15 17:37:30.917 UTC: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
047643: Mar 15 17:37:30.921 UTC: htsp_timer - 120000 msec
047644: Mar 15 17:37:30.921 UTC: htsp_pre_connect_disconnect, cdb = 2AD1D540 cause = 1
047645: Mar 15 17:37:30.921 UTC: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
047646: Mar 15 17:37:30.921 UTC: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec htsp_release_req: cause 1, no_onhook 0
047647: Mar 15 17:37:32.921 UTC: htsp_process_event: [0/0/0, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
047648: Mar 15 17:37:32.921 UTC: htsp_timer_stop
047649: Mar 15 17:37:32.921 UTC: htsp_timer_stop2
047650: Mar 15 17:37:32.921 UTC: htsp_timer_stop3
047651: Mar 15 17:37:32.921 UTC: [0/0/0] set signal state = 0x4 timestamp = 0
047652: Mar 15 17:37:32.921 UTC: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0x4 timestamp=0x0
047653: Mar 15 17:37:32.921 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
047654: Mar 15 17:37:32.921 UTC: htsp_timer - 2000 msec
047655: Mar 15 17:37:32.921 UTC: TGRM: reg_invoke_tgrm_channel_service_update(0, 0, 0, 65535, 1)
047656: Mar 15 17:37:32.921 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
047657: Mar 15 17:37:32.921 UTC: flex_dsprm_close_cleanup
047658: Mar 15 17:37:34.921 UTC: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
047659: Mar 15 17:37:34.921 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
047660: Mar 15 17:37:34.921 UTC: dsp_req_sig_state: [0/0/0] packet_len=8 channel_id=128 packet_id=40
047661: Mar 15 17:37:34.921 UTC: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
03-15-2013 10:40 AM
What number did you dial? From the debug it looks like you dialed 6123 which wouldn't match the destination-pattern 9T in dial-peer 20
03-15-2013 10:44 AM
Calling number 7872350808 and called is 7872753003 wich should be directed to extension 4123.
03-15-2013 10:45 AM
So this is an inbound call?
03-15-2013 10:48 AM
Yes.
03-15-2013 10:50 AM
In all the prior discussions been talking about outbound calls. For inbound calls just add 'connection plar 4123' on the voice-port 0/0/0
03-15-2013 10:56 AM
Great! Inbound working. Now lets work out outbound! Thanks again!
03-15-2013 11:01 AM
Outbound call debug (calling from extension 4123 to number 7872350808):
051804: Mar 15 18:04:58.125 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
051805: Mar 15 18:04:58.125 UTC: //-1/dpMatchPeersCore:
051806: Mar 15 18:04:58.125 UTC: //-1/dpMatchSafModulePlugin:
dialstring=, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
051807: Mar 15 18:04:58.125 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
051808: Mar 15 18:04:58.129 UTC: htsp_process_event: [50/0/8.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
051809: Mar 15 18:04:58.129 UTC: [50/0/8.1] get_local_station_id calling num=4123 calling name=7875239999 calling time=03/15 18:04 orig called=
051810: Mar 15 18:04:58.129 UTC: TGRM: reg_invoke_tgrm_accept_call(0, TGRM_CALL_VOICE, TGRM_DIRECTION_IN, 50, 0, 8, 65535)
051811: Mar 15 18:04:58.129 UTC: TGRM: Calling vtsp_tsp_call_setup_ind().
051812: Mar 15 18:04:58.129 UTC: //-1/dpAssociateIncomingPeerCore:
Calling Number=4123, Called Number=, Voice-Interface=0x2BAD8ED8,
051813: Mar 15 18:04:58.129 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=4123
051814: Mar 15 18:04:58.129 UTC: //-1/dpMatchPeertype:
051815: Mar 15 18:04:58.129 UTC: //-1/dpMatchCore:
Dial String=, Expanded String=, Calling Number=4123T
051816: Mar 15 18:04:58.129 UTC: //-1/dpMatchCore:
Result=-1
051817: Mar 15 18:04:58.129 UTC: //-1/dpMatchPeertype:exit@5985
051818: Mar 15 18:04:58.129 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=4123
051819: Mar 15 18:04:58.129 UTC: //-1/dpMatchPeertype:
051820: Mar 15 18:04:58.129 UTC: //-1/dpMatchCore:
051821: Mar 15 18:04:58.129 UTC: //-1/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20008 Is Matched
051822: Mar 15 18:04:58.129 UTC: //-1/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=21 Is Matched
051823: Mar 15 18:04:58.129 UTC: //-1/dpMatchPeertype:exit@5985
051824: Mar 15 18:04:58.129 UTC: //-1/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20008
051825: Mar 15 18:04:58.129 UTC: //-1/dpMatchSafModulePlugin:
051826: Mar 15 18:04:58.129 UTC: //-1/dpAssociateIncomingPeerSPI:exit@6564
051827: Mar 15 18:04:58.129 UTC: TGRM: reg_invoke_tgrm_call_update(50, 0, 8, 65535, 0, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
051828: Mar 15 18:04:58.129 UTC: htsp_process_event: [50/0/8.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
051829: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051830: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_OPEN_VOICE_CHANNEL
051831: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051832: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ENC_CONFIG 2
051833: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051834: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_SET_VOICE_PLAYOUT_DELAY
051835: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051836: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051837: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ECHO_CANCELLER_CONTROL
051838: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051839: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_VOICE_MODE codec=1 vad=0 size=160 edsp_state=0
051840: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051841: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ECHO_CANCELLER_CONTROL
051842: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051843: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_SET_GAINS
051844: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051845: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051846: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051847: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051848: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_DTMF_MODE
051849: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051850: Mar 15 18:04:58.129 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_CP_TONE_ON 4 dir 1
051851: Mar 15 18:04:58.749 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051852: Mar 15 18:04:58.749 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_CP_TONE_OFF
051853: Mar 15 18:04:58.753 UTC: htsp_digit_ready(50/0/8.1): digit = 9
051854: Mar 15 18:04:58.753 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
051855: Mar 15 18:04:58.753 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_DTMF_MODE
051856: Mar 15 18:04:58.753 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=9, Peer Info Type=DIALPEER_INFO_SPEECH
051857: Mar 15 18:04:58.753 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9
051858: Mar 15 18:04:58.753 UTC: //-1/dpMatchCore:
Dial String=9, Expanded String=9, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
051859: Mar 15 18:04:58.753 UTC: //-1/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=5
051860: Mar 15 18:04:58.753 UTC: //-1/dpMatchCore:
Result=1
051861: Mar 15 18:04:58.753 UTC: //-1/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
051862: Mar 15 18:04:58.753 UTC: //-1/dpMatchSafModulePlugin:
dialstring=9, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051863: Mar 15 18:04:58.753 UTC: //-1/dpMatchPeersMoreArg:
051864: Mar 15 18:04:59.145 UTC: htsp_digit_ready(50/0/8.1): digit = 7
051865: Mar 15 18:04:59.145 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=97, Peer Info Type=DIALPEER_INFO_SPEECH
051866: Mar 15 18:04:59.145 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=97
051867: Mar 15 18:04:59.145 UTC: //-1/dpMatchCore:
Dial String=97, Expanded String=97, Calling Number=
051868: Mar 15 18:04:59.145 UTC: //-1/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=20
051869: Mar 15 18:04:59.145 UTC: //-1/dpMatchCore:
Result=1
051870: Mar 15 18:04:59.145 UTC: //-1/dpMatchPeersCore:
051871: Mar 15 18:04:59.145 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051872: Mar 15 18:04:59.145 UTC: //-1/dpMatchPeersMoreArg:
051873: Mar 15 18:04:59.385 UTC: htsp_digit_ready(50/0/8.1): digit = 8
051874: Mar 15 18:04:59.385 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=978, Peer Info Type=DIALPEER_INFO_SPEECH
051875: Mar 15 18:04:59.385 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=978
051876: Mar 15 18:04:59.385 UTC: //-1/dpMatchCore:
Dial String=978, Expanded String=978, Calling Number=
051877: Mar 15 18:04:59.385 UTC: //-1/MatchNextPeer:
051878: Mar 15 18:04:59.385 UTC: //-1/dpMatchCore:
Result=1
051879: Mar 15 18:04:59.385 UTC: //-1/dpMatchPeersCore:
051880: Mar 15 18:04:59.385 UTC: //-1/dpMatchSafModulePlugin:
dialstring=978, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051881: Mar 15 18:04:59.385 UTC: //-1/dpMatchPeersMoreArg:
051882: Mar 15 18:04:59.577 UTC: htsp_digit_ready(50/0/8.1): digit = 7
051883: Mar 15 18:04:59.577 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=9787, Peer Info Type=DIALPEER_INFO_SPEECH
051884: Mar 15 18:04:59.577 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9787
051885: Mar 15 18:04:59.577 UTC: //-1/dpMatchCore:
Dial String=9787, Expanded String=9787, Calling Number=
051886: Mar 15 18:04:59.577 UTC: //-1/MatchNextPeer:
051887: Mar 15 18:04:59.577 UTC: //-1/dpMatchCore:
Result=1
051888: Mar 15 18:04:59.577 UTC: //-1/dpMatchPeersCore:
051889: Mar 15 18:04:59.577 UTC: //-1/dpMatchSafModulePlugin:
dialstring=9787, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051890: Mar 15 18:04:59.577 UTC: //-1/dpMatchPeersMoreArg:
051891: Mar 15 18:04:59.857 UTC: htsp_digit_ready(50/0/8.1): digit = 2
051892: Mar 15 18:04:59.857 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=97872, Peer Info Type=DIALPEER_INFO_SPEECH
051893: Mar 15 18:04:59.857 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=97872
051894: Mar 15 18:04:59.857 UTC: //-1/dpMatchCore:
Dial String=97872, Expanded String=97872, Calling Number=
051895: Mar 15 18:04:59.857 UTC: //-1/MatchNextPeer:
051896: Mar 15 18:04:59.857 UTC: //-1/dpMatchCore:
Result=1
051897: Mar 15 18:04:59.857 UTC: //-1/dpMatchPeersCore:
051898: Mar 15 18:04:59.857 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97872, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051899: Mar 15 18:04:59.857 UTC: //-1/dpMatchPeersMoreArg:
051900: Mar 15 18:05:00.073 UTC: htsp_digit_ready(50/0/8.1): digit = 3
051901: Mar 15 18:05:00.073 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=978723, Peer Info Type=DIALPEER_INFO_SPEECH
051902: Mar 15 18:05:00.073 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=978723
051903: Mar 15 18:05:00.073 UTC: //-1/dpMatchCore:
Dial String=978723, Expanded String=978723, Calling Number=
051904: Mar 15 18:05:00.073 UTC: //-1/MatchNextPeer:
051905: Mar 15 18:05:00.073 UTC: //-1/dpMatchCore:
Result=1
051906: Mar 15 18:05:00.073 UTC: //-1/dpMatchPeersCore:
051907: Mar 15 18:05:00.073 UTC: //-1/dpMatchSafModulePlugin:
dialstring=978723, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051908: Mar 15 18:05:00.073 UTC: //-1/dpMatchPeersMoreArg:
051909: Mar 15 18:05:00.293 UTC: htsp_digit_ready(50/0/8.1): digit = 5
051910: Mar 15 18:05:00.293 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=9787235, Peer Info Type=DIALPEER_INFO_SPEECH
051911: Mar 15 18:05:00.293 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9787235
051912: Mar 15 18:05:00.293 UTC: //-1/dpMatchCore:
Dial String=9787235, Expanded String=9787235, Calling Number=
051913: Mar 15 18:05:00.293 UTC: //-1/MatchNextPeer:
051914: Mar 15 18:05:00.293 UTC: //-1/dpMatchCore:
Result=1
051915: Mar 15 18:05:00.293 UTC: //-1/dpMatchPeersCore:
051916: Mar 15 18:05:00.293 UTC: //-1/dpMatchSafModulePlugin:
dialstring=9787235, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051917: Mar 15 18:05:00.293 UTC: //-1/dpMatchPeersMoreArg:
051918: Mar 15 18:05:00.577 UTC: htsp_digit_ready(50/0/8.1): digit = 0
051919: Mar 15 18:05:00.577 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=97872350, Peer Info Type=DIALPEER_INFO_SPEECH
051920: Mar 15 18:05:00.577 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=97872350
051921: Mar 15 18:05:00.577 UTC: //-1/dpMatchCore:
Dial String=97872350, Expanded String=97872350, Calling Number=
051922: Mar 15 18:05:00.577 UTC: //-1/MatchNextPeer:
051923: Mar 15 18:05:00.577 UTC: //-1/dpMatchCore:
Result=1
051924: Mar 15 18:05:00.577 UTC: //-1/dpMatchPeersCore:
051925: Mar 15 18:05:00.577 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97872350, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051926: Mar 15 18:05:00.577 UTC: //-1/dpMatchPeersMoreArg:
051927: Mar 15 18:05:00.769 UTC: htsp_digit_ready(50/0/8.1): digit = 8
051928: Mar 15 18:05:00.769 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=978723508, Peer Info Type=DIALPEER_INFO_SPEECH
051929: Mar 15 18:05:00.769 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=978723508
051930: Mar 15 18:05:00.769 UTC: //-1/dpMatchCore:
Dial String=978723508, Expanded String=978723508, Calling Number=
051931: Mar 15 18:05:00.769 UTC: //-1/MatchNextPeer:
051932: Mar 15 18:05:00.769 UTC: //-1/dpMatchCore:
Result=1
051933: Mar 15 18:05:00.769 UTC: //-1/dpMatchPeersCore:
051934: Mar 15 18:05:00.769 UTC: //-1/dpMatchSafModulePlugin:
dialstring=978723508, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051935: Mar 15 18:05:00.769 UTC: //-1/dpMatchPeersMoreArg:
051936: Mar 15 18:05:00.993 UTC: htsp_digit_ready(50/0/8.1): digit = 0
051937: Mar 15 18:05:00.993 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=9787235080, Peer Info Type=DIALPEER_INFO_SPEECH
051938: Mar 15 18:05:00.993 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9787235080
051939: Mar 15 18:05:00.993 UTC: //-1/dpMatchCore:
Dial String=9787235080, Expanded String=9787235080, Calling Number=
051940: Mar 15 18:05:00.993 UTC: //-1/MatchNextPeer:
051941: Mar 15 18:05:00.993 UTC: //-1/dpMatchCore:
Result=1
051942: Mar 15 18:05:00.993 UTC: //-1/dpMatchPeersCore:
051943: Mar 15 18:05:00.993 UTC: //-1/dpMatchSafModulePlugin:
dialstring=9787235080, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
051944: Mar 15 18:05:00.993 UTC: //-1/dpMatchPeersMoreArg:
051945: Mar 15 18:05:01.193 UTC: htsp_digit_ready(50/0/8.1): digit = 8
051946: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=97872350808, Peer Info Type=DIALPEER_INFO_SPEECH
051947: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=97872350808
051948: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
Dial String=97872350808, Expanded String=97872350808, Calling Number=
051949: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20 Is Matched
051950: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
051951: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97872350808, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
051952: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20
051953: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051954: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051955: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
051956: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
051957: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051958: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97872350808, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
051959: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
051960: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051961: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051962: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
051963: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
051964: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051965: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
051966: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
051967: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
Calling Number=97872350808, Called Number=97872350808, Peer Info Type=DIALPEER_INFO_SPEECH
051968: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051969: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
Dial String=97872350808, Expanded String=97872350808, Calling Number=97872350808T
051970: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
051971: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051972: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
051973: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
051974: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
051975: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
051976: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
051977: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeer:exit@6613
051978: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
Calling Number=97872350808, Called Number=, Voice-Interface=0x0,
051979: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=97872350808
051980: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeertype:
051981: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
Dial String=, Expanded String=, Calling Number=97872350808T
051982: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
Result=-1
051983: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeertype:exit@5985
051984: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=97872350808
051985: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeertype:
051986: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
051987: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20 Is Matched
051988: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeertype:exit@5985
051989: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeerCore:
051990: Mar 15 18:05:01.193 UTC: //-1/dpMatchSafModulePlugin:
051991: Mar 15 18:05:01.193 UTC: //-1/dpAssociateIncomingPeer:exit@6613
051992: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051993: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051994: Mar 15 18:05:01.193 UTC: //-1/dpMatchCore:
051995: Mar 15 18:05:01.193 UTC: //-1/MatchNextPeer:
051996: Mar 15 18:05:01.193 UTC: //-1/dpMatchPeersCore:
051997: Mar 15 18:05:01.197 UTC: //-1/dpMatchSafModulePlugin:
051998: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
051999: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052000: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052001: Mar 15 18:05:01.197 UTC: //-1/dpMatchCore:
052002: Mar 15 18:05:01.197 UTC: //-1/MatchNextPeer:
052003: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052004: Mar 15 18:05:01.197 UTC: //-1/dpMatchSafModulePlugin:
dialstring=97872350808, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
052005: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
052006: Mar 15 18:05:01.197 UTC: htsp_timer_stop3
052007: Mar 15 18:05:01.197 UTC: htsp_process_event: [50/0/8.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
052008: Mar 15 18:05:01.197 UTC: [50/0/8.1] set signal state = 0x8 timestamp = 0
052009: Mar 15 18:05:01.197 UTC: edsp_set_sig_state: [50/0/8.1] packet_len=12 channel_id=57 packet_id=39 state=0x8 timestamp=0x0
052010: Mar 15 18:05:01.197 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052011: Mar 15 18:05:01.197 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 EFXS_PROCEEDING
052012: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052013: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052014: Mar 15 18:05:01.197 UTC: //-1/dpMatchCore:
052015: Mar 15 18:05:01.197 UTC: //-1/MatchNextPeer:
052016: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052017: Mar 15 18:05:01.197 UTC: //-1/dpMatchSafModulePlugin:
052018: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
052019: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052020: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052021: Mar 15 18:05:01.197 UTC: //-1/dpMatchCore:
052022: Mar 15 18:05:01.197 UTC: //-1/MatchNextPeer:
052023: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersCore:
052024: Mar 15 18:05:01.197 UTC: //-1/dpMatchSafModulePlugin:
052025: Mar 15 18:05:01.197 UTC: //-1/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20htsp_setup_req
052026: Mar 15 18:05:01.197 UTC: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
052027: Mar 15 18:05:01.201 UTC: [0/0/0] set signal state = 0xC timestamp = 0
052028: Mar 15 18:05:01.201 UTC: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0xC timestamp=0x0
052029: Mar 15 18:05:01.201 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
052030: Mar 15 18:05:01.201 UTC: htsp_timer - 1300 msec
052031: Mar 15 18:05:02.501 UTC: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer htsp_dial
052032: Mar 15 18:05:02.501 UTC: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
052033: Mar 15 18:05:03.929 UTC: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
052034: Mar 15 18:05:03.929 UTC: htsp_timer - 350 msec
052035: Mar 15 18:05:03.929 UTC: htsp_call_bridged invoked
052036: Mar 15 18:05:03.929 UTC: htsp_call_bridged invoked
052037: Mar 15 18:05:03.929 UTC: flex_modem_relay_supported:Modem Relay supported. flex_type=1htsp_progress_notify
052038: Mar 15 18:05:03.929 UTC: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
052039: Mar 15 18:05:03.929 UTC: flex_dsprm_forking_mixing_support:
052040: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=4123, Peer Info Type=DIALPEER_INFO_SPEECH
052041: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=4123
052042: Mar 15 18:05:03.929 UTC: //-1/dpMatchCore:
Dial String=4123, Expanded String=4123, Calling Number=
052043: Mar 15 18:05:03.929 UTC: //-1/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20008 Is Matched
052044: Mar 15 18:05:03.929 UTC: //-1/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=21 Is Matched
052045: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
052046: Mar 15 18:05:03.929 UTC: //-1/dpMatchSafModulePlugin:
052047: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=20008
2: Dial-peer Tag=21
052048: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
Calling Number=, Called Number=2350808, Peer Info Type=DIALPEER_INFO_SPEECH
052049: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=2350808
052050: Mar 15 18:05:03.929 UTC: //-1/dpMatchCore:
Dial String=2350808, Expanded String=2350808, Calling Number=
052051: Mar 15 18:05:03.929 UTC: //-1/dpMatchCore:
Result=-1
052052: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
052053: Mar 15 18:05:03.929 UTC: //-1/dpMatchSafModulePlugin:
052054: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeers:
Result=NO_MATCH(-1)htsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
052055: Mar 15 18:05:03.929 UTC: htsp_process_event: [50/0/8.1, EFXS_OFFHOOK, E_HTSP_CALLERID_WAITING]
052056: Mar 15 18:05:03.929 UTC: efxs_callerid_update
052057: Mar 15 18:05:03.929 UTC: efxs_callerid_update process caller_id_string
052058: Mar 15 18:05:03.929 UTC: efxs_callerid_update process caller_id_string OK
052059: Mar 15 18:05:03.929 UTC: efxs_callerid_update number= [2350808] name= []
052060: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
052061: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
052062: Mar 15 18:05:03.929 UTC: //-1/dpMatchCore:
052063: Mar 15 18:05:03.929 UTC: //-1/dpMatchCore:
Result=-1
052064: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersCore:
052065: Mar 15 18:05:03.929 UTC: //-1/dpMatchSafModulePlugin:
dialstring=2350808, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
052066: Mar 15 18:05:03.929 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052067: Mar 15 18:05:03.929 UTC: mars_flex_dsprm_current_codec_comp:DSP:0 FLEX Complexity Codec
052068: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052069: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_IDLE_MODE
052070: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052071: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ENC_CONFIG 2
052072: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052073: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_SET_VOICE_PLAYOUT_DELAY
052074: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052075: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052076: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ECHO_CANCELLER_CONTROL
052077: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052078: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_VOICE_MODE codec=1 vad=0 size=160 edsp_state=4
052079: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052080: Mar 15 18:05:03.929 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_ECHO_CANCELLER_CONTROL
052081: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052082: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_SET_GAINS
052083: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052084: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052085: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052086: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052087: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052088: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052089: Mar 15 18:05:03.933 UTC: htsp_process_event: [50/0/8.1, EFXS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]efxs_offhook_cutthru
052090: Mar 15 18:05:03.933 UTC: [50/0/8.1] set signal state = 0x7 timestamp = 0
052091: Mar 15 18:05:03.933 UTC: edsp_set_sig_state: [50/0/8.1] packet_len=12 channel_id=57 packet_id=39 state=0x7 timestamp=0x0
052092: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052093: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 EFXS_OPEN_VOICE_PATH count=1
052094: Mar 15 18:05:03.933 UTC: htsp_process_event: [0/0/0, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
052095: Mar 15 18:05:03.933 UTC: htsp_timer_stop
052096: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052097: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052098: Mar 15 18:05:03.933 UTC: //-1/dpMatchCore:
052099: Mar 15 18:05:03.933 UTC: //-1/MatchNextPeer:
052100: Mar 15 18:05:03.933 UTC: //-1/MatchNextPeer:
052101: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052102: Mar 15 18:05:03.933 UTC: //-1/dpMatchSafModulePlugin:
052103: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeers:
Result=SUCCESS(0)
2: Dial-peer Tag=21
052104: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052105: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052106: Mar 15 18:05:03.933 UTC: //-1/dpMatchCore:
052107: Mar 15 18:05:03.933 UTC: //-1/dpMatchCore:
Result=-1
052108: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052109: Mar 15 18:05:03.933 UTC: //-1/dpMatchSafModulePlugin:
052110: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeers:
Result=NO_MATCH(-1)htsp_connect: no_offhook 0 call_connected 0htsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 1
052111: Mar 15 18:05:03.933 UTC: htsp_process_event: [50/0/8.1, EFXS_OFFHOOK, E_HTSP_CONNECT]efxs_offhook_connect
052112: Mar 15 18:05:03.933 UTC: [50/0/8.1] set signal state = 0x6 timestamp = 0
052113: Mar 15 18:05:03.933 UTC: edsp_set_sig_state: [50/0/8.1] packet_len=12 channel_id=57 packet_id=39 state=0x6 timestamp=0x0
052114: Mar 15 18:05:03.933 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052115: Mar 15 18:05:03.933 UTC: //-1/dpMatchPeersCore:
052116: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052117: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
052118: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
Result=-1
052119: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052120: Mar 15 18:05:03.937 UTC: //-1/dpMatchSafModulePlugin:
052121: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052122: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052123: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052124: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
052125: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
Result=-1
052126: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052127: Mar 15 18:05:03.937 UTC: //-1/dpMatchSafModulePlugin:
052128: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052129: Mar 15 18:05:03.937 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 EFXS_RVS_BATTERY
052130: Mar 15 18:05:03.937 UTC: htsp_process_event: [50/0/8.1, EFXS_CONNECT, E_HTSP_CALLERID_WAITING]
052131: Mar 15 18:05:03.937 UTC: efxs_callerid_update
052132: Mar 15 18:05:03.937 UTC: efxs_callerid_update process caller_id_string
052133: Mar 15 18:05:03.937 UTC: efxs_callerid_update process caller_id_string OK
052134: Mar 15 18:05:03.937 UTC: efxs_callerid_update number= [2350808] name= []
052135: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052136: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052137: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
052138: Mar 15 18:05:03.937 UTC: //-1/dpMatchCore:
Result=-1
052139: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersCore:
052140: Mar 15 18:05:03.937 UTC: //-1/dpMatchSafModulePlugin:
052141: Mar 15 18:05:03.937 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052142: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052143: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052144: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
052145: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
Result=-1
052146: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052147: Mar 15 18:05:04.481 UTC: //-1/dpMatchSafModulePlugin:
052148: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052149: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052150: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052151: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
052152: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
Result=-1
052153: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052154: Mar 15 18:05:04.481 UTC: //-1/dpMatchSafModulePlugin:
052155: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052156: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052157: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052158: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
052159: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
Result=-1
052160: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052161: Mar 15 18:05:04.481 UTC: //-1/dpMatchSafModulePlugin:
052162: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052163: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052164: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052165: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
052166: Mar 15 18:05:04.481 UTC: //-1/dpMatchCore:
Result=-1
052167: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersCore:
052168: Mar 15 18:05:04.481 UTC: //-1/dpMatchSafModulePlugin:
052169: Mar 15 18:05:04.481 UTC: //-1/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
052170: Mar 15 18:05:04.485 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052171: Mar 15 18:05:04.485 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GEN_PACKET_CONTROL
052172: Mar 15 18:05:05.373 UTC: htsp_timer_stop3
052173: Mar 15 18:05:05.373 UTC: htsp_timer_stop3
052174: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052175: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_TX_STAT
052176: Mar 15 18:05:05.377 UTC: edsp_fake_tx_stat: [50/0/8.1] DN=8 chnl=57 by proc_id 6
052177: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052178: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_RX_STAT
052179: Mar 15 18:05:05.377 UTC: edsp_fake_rx_stat: [50/0/8.1] DN=8 chnl=57 by proc_id 6
052180: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052181: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_LEVELS
052182: Mar 15 18:05:05.377 UTC: edsp_fake_levels: [50/0/8.1] DN=8 chnl=57 by proc_id 6
052183: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052184: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_TX_STAT
052185: Mar 15 18:05:05.377 UTC: edsp_fake_tx_stat: [50/0/8.1] DN=8 chnl=57 by proc_id 8
052186: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052187: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_RX_STAT
052188: Mar 15 18:05:05.377 UTC: edsp_fake_rx_stat: [50/0/8.1] DN=8 chnl=57 by proc_id 8
052189: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052190: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_VOICE_PLAYOUT_DELAY
052191: Mar 15 18:05:05.377 UTC: edsp_fake_voice_playout_delay: [50/0/8.1] DN=8 chnl=57 by proc_id 8
052192: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052193: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_VOICE_PLAYOUT_ERROR
052194: Mar 15 18:05:05.377 UTC: edsp_fake_voice_playout_error: [50/0/8.1] DN=8 chnl=57 by proc_id 8
052195: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052196: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_GET_LEVELS
052197: Mar 15 18:05:05.377 UTC: edsp_fake_levels: [50/0/8.1] DN=8 chnl=57 by proc_id 8
052198: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052199: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 GET_ERROR_STAT
052200: Mar 15 18:05:05.377 UTC: edsp_fake_error_stat: [50/0/8.1] DN=8 chnl=57 by proc_id 8htsp_release_req: cause 16, no_onhook 0
052201: Mar 15 18:05:05.377 UTC: htsp_process_event: [50/0/8.1, EFXS_CONNECT, E_HTSP_RELEASE_REQ]efxs_connect_disc
052202: Mar 15 18:05:05.377 UTC: htsp_timer_stop
052203: Mar 15 18:05:05.377 UTC: [50/0/8.1] set signal state = 0xC timestamp = 0
052204: Mar 15 18:05:05.377 UTC: edsp_set_sig_state: [50/0/8.1] packet_len=12 channel_id=57 packet_id=39 state=0xC timestamp=0x0
052205: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052206: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 EFXS_SUP_DISC (cause 16)
052207: Mar 15 18:05:05.377 UTC: [50/0/8.1] set signal state = 0x4 timestamp = 0
052208: Mar 15 18:05:05.377 UTC: edsp_set_sig_state: [50/0/8.1] packet_len=12 channel_id=57 packet_id=39 state=0x4 timestamp=0x0
052209: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052210: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 StationRingOffefxs_cpc_timer
052211: Mar 15 18:05:05.377 UTC: edsp_req_sig_state: [50/0/8.1] packet_len=8 channel_id=57 packet_id=40
052212: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052213: Mar 15 18:05:05.377 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 Request State
052214: Mar 15 18:05:05.377 UTC: htsp_timer - 30000 msec
052215: Mar 15 18:05:05.377 UTC: htsp_process_event: [50/0/8.1, EFXS_WAIT_ONHOOK, E_DSP_SIG_0100]efxs_waitonhook_onhook
052216: Mar 15 18:05:05.377 UTC: htsp_timer_stop htsp_report_onhook_sig
052217: Mar 15 18:05:05.377 UTC: TGRM: reg_invoke_tgrm_call_update(50, 0, 8, 65535, 0, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
052218: Mar 15 18:05:05.389 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052219: Mar 15 18:05:05.389 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_IDLE_MODE
052220: Mar 15 18:05:05.389 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57
052221: Mar 15 18:05:05.389 UTC: edsp_soutput: [50/0/8.1] DN=8 chnl=57 MSG_RX_CLOSE_VOICE_CHANNEL
052222: Mar 15 18:05:05.389 UTC: edsprm_close_cleanuphtsp_release_req: cause 16, no_onhook 0
052223: Mar 15 18:05:06.093 UTC: htsp_process_event: [0/0/0, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
052224: Mar 15 18:05:06.093 UTC: htsp_timer_stop
052225: Mar 15 18:05:06.093 UTC: htsp_timer_stop2
052226: Mar 15 18:05:06.093 UTC: htsp_timer_stop3
052227: Mar 15 18:05:06.093 UTC: [0/0/0] set signal state = 0x4 timestamp = 0
052228: Mar 15 18:05:06.093 UTC: dsp_set_sig_state: [0/0/0] packet_len=12 channel_id=128 packet_id=39 state=0x4 timestamp=0x0
052229: Mar 15 18:05:06.093 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
052230: Mar 15 18:05:06.093 UTC: htsp_timer - 2000 msec
052231: Mar 15 18:05:06.093 UTC: TGRM: reg_invoke_tgrm_channel_service_update(0, 0, 0, 65535, 1)
052232: Mar 15 18:05:06.093 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
052233: Mar 15 18:05:06.097 UTC: flex_dsprm_close_cleanup
052234: Mar 15 18:05:08.093 UTC: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
052235: Mar 15 18:05:08.093 UTC: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
052236: Mar 15 18:05:08.093 UTC: dsp_req_sig_state: [0/0/0] packet_len=8 channel_id=128 packet_id=40
052237: Mar 15 18:05:08.093 UTC: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0100]qundeb
03-15-2013 11:35 AM
Guys, I configured the outbound dialpeer like this:
dial-peer voice 20 pots
description Outbound Calls in MHQ
destination-pattern 9787.......
port 0/0/0
forward-digits 10
The behaviour is when placing an outbound call in SRST, it seems like the voice gateway attempts to place the call but it get dropped.
Do i have to strip digit 9 on this dialpeer? Below is call setup debug:
052879: Mar 15 18:21:22.941 UTC: //6753/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=4123
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=97872350808
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
03-15-2013 01:20 PM
Your debug shows no dial peer being matched as something is stripping your 9787 then sending only 2350808. Might need to post your entire config.
Result=-1
Result=NO_MATCH(-1)
Result=-1
03-15-2013 01:58 PM
Hello Tracy and thanks for your reply. I resolved that issue. Right now, the problem lies when placing outbound calls, the 9 is being sent to the PSTN and call is not progressing (at least, that is what I can see from the debugs). This is an output from the debug voice ccapi all (calling from extension 4123 to number 7872350808):
ccCallSetupRequest:
cisco-username=
cisco-ani=4123
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=97872350808
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
The matched dialpeer is as follows:
port 0/0/0
Two questions: Should digit 9 been stripped off automatically or should it be done manually on this dialpeer? Should calling number 4123 be masked into the number assigned by the PSTN into FXO port 0/0/0?
Thanks again!
03-15-2013 10:49 AM
When calling outbound, the phone rings once, then get disconnected.
03-15-2013 10:42 AM
Also got this error:
048107: Mar 15 17:46:35.537 UTC: %CALL_CONTROL-6-APP_NOT_FOUND: Application mgcpapp in dial-peer 999000 not found. Handing callid 6642 to the alternate app Default.voip
Thanks in advanced for your help!
03-15-2013 10:43 AM
That is expected since you are in SRST.
