10-21-2022 08:20 AM
Hello, We are going to install a new SRST ISR4351 on a site.
I am used to configuring remote sites with ISR43xx with FXO ports in H.323 and/or MGCP (we use both). I always use a "connection plar" to go to an auto-attendant (in H.323) and I use the "attendant DN" in CUCM in MGCP.
As we are using "auto-attendant DN" or "Connection Plar", we already have a CTI Route Point configured (Cisco Unity).
Now this new site is bigger and we are going to install a T1 PRI. The commerical PSTN line comes with 10 digits, but in my cluster, I use 7 completely different digits. How can I easily direct all calls to the auto-attendant?
Any help will be helpful, thanks!
Solved! Go to Solution.
10-24-2022 05:52 AM
10-22-2022 05:18 AM
if using MGCP you will need to use CUCM Translation Patterns on the incoming CSS of the PRI. If H.323 (reminder: this is EoL as of IOS-XE 17.6) you can also use a translation rule/profile on the gateway itself before the call is sent to CUCM
10-24-2022 03:42 AM
Hello, Thanks for the reply, and sorry for my English
2 points to clarify please
1 - Do I understand correctly that from version 17.6 (IOS of the router), only MGCP will be available?
2 - For the Transformation Pattern in MGCP: - If I configure the T1 PRI (with all the CSS,etc...) in (Call Routing Information - Inbound Calls) to accept "Significant Digits: 10", I must configure a translation pattern with these 10 digits (received from the PSTN called number) and in the "Called Party Transformations" configure the "Called Party Transformation Mask" has an internal 7-digit number such as a CTI Route Point? As simple as that?
Thanks again!
10-24-2022 05:52 AM
