srstrouter
in our project we are using branch site srst router with unity exprsss and in head office site call manger{one publisher and four subcriber}  server
how to integrate srst unity express with head office call manger and in router site how to create dial-peer configuration for voice mail
Ayodeji Okanlawon
I assume you want to integrate CUCM with Unity express voicemail...
There are a few documenation you can use..
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
http://voiceonbits.com/2010/07/17/cisco-unity-express-setup-cue-cucm/
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
In addition to the correct links provided above, just to summarise:
To integrate CUE with CUCM follow below steps:
In CUCM:
1) Create CTI route point with directory number as your Voicemail number.
2) Create CTI ports
3) Create an application username and pwd. For example username cuejtapi, pwd: ciscocisco
4) Associate the ctiports and cti rp with this username.
On CME router:
under telephony-service
voicemail XXXX
mwi relay
sip-ua
mwi ipv4:X.X.X.X unsolicited   <<<< X.X.X.X is ip address of CUE
You dont need any separate mwi numbers with unsolicited. Voicemail server automatically sends SIP notification.
on CUE
ccn sub jtapi
ccm add A.A.A.A  << ip add of CUCM
ccm username cuejtapi pas ciscocisco
ctiport X Y Z
ccn trigger jta pho XXXX << your VM number
app voicemail
enab
end
ccn sub sip
gatew add X.X.X.X <<< CME ip add (This is for SRST voicemail)
mwi sip unsol
end
ccn trigger sip pho XXXX << your VM number
app voicemail
enab
end
username X create   < X = username
username X phonenumber Y  < Y = phonenumber of X
voicemail mailbox owner X s 2964
no tut   (disables first time tutorial, skip this if you need it)
enab
end
username X pin 12345
*Please excuse any syntax mistake as I dont have CLI in front of me*
Please rate all helpful posts. Mark all questions as answered if you dont have any further queries and if possible please refrain from opening duplicate questions\threads.
Terry
