ā05-20-2012 05:52 PM - edited ā03-16-2019 11:15 AM
Hi, people! I need help.
I am setting up call encryption for a nework, and I an finding issues with a gateway.
I have an H323 gateways connected to the PSTN through an E1 interface.
The outgoing calls go through a TCL script that triggers a billing application.
When I set up the gateway to use SRTP, I use the following commands.
voice service voip
srtp fallback
From there, when I make a call to the PSTN, the SRTP leg of the call is not encrypted whenever the call goes through the TCL dialpeer.
If I route the calls to the PSTN through an alternate dialpeer that does not trigger the TCL script, the call is encrypted correctly.
Is thera any known interactions between SRTP and TCLs that I am not aware of?
I canĀ“t find any reference.
Ariel
Solved! Go to Solution.
ā06-04-2012 11:29 AM
Just for the record and future references, SRTP with TCL scripts is not supported.
Tere.
If you find this post helpful, please rate!
Tere.
