How do I re-set the time on our CISCO 7960 series IP Phone due to a power outage in building where time is now 14 minutes off? I've gone into CallManager, and can't seem to locate where to change the minutes. Any help will be app...
hi! In CM7, i can see that there are many places that i can specify paramenters of Called Party Transformations & Calling Party Transformation. Eg, in the Route Pattern, Route List and etc.From the description of the configuration page (to my underst...
I'm having an unusual issue with some of my FXO ports at one location.When on a call through the PSTN (FXO to analog line) I can hear the other party fine as long as I don't make any noise. However, as soon as I start speaking the inbound audio is d...
HelloI have about 100 Cisco 7911 deloyed in a hospital and every week I have problems with them, because patients change the RJ45 from the switch port to the PC port and the phone stops working (bored people is very dangeorus if they have a phone wit...
Hi All,How can I setup sRTP on CUCM 8.6.Thank you for your help in advance.PaulSent from Cisco Technical Support iPad App
Hello,I have CUCM 8.0 and UCX 8.0 connected via SCCP. I configure VGW with CUCM as H323 GW with CSS can reach everywhere and VP ports can reach everywhere.I configure a CTI RP with FWD-All to VM and on UCX configured a call handler and allowed transf...
Hello guys do you please remember the bug ID for phones getting ip from Data Vlan?
Hello,We have configured MGCP Protocol on cisco router using PRI with NI2 switch type and working fine, but for temporarty basis we have to switchover to NI1Is there possibililty to change the NI2 to NI1 and if yes how could we do that?ThanksRegards,...
dears,any one can help, i have these config in my translation rulesincoming calls are working when i dial 2837555 from outside , but some are saying that when they call from certain numbers the number 2837555 it will be busy. !voice...
Does anyone know the file name that is populated in the "Load Information" field on the Device Defaults page of CUCM 7.1.5 for an 8945 SCCP phone for firmeware cmterm-8941_8945-sccp.9-3-1-19.cop.sgn?joe.
Dear Friends,Our Helpdesk calls are gettings transferred from IVR...However, the "Transfer" Option is INACTIVE. Can anyone help me with this?Regards,Ifthiquar.
Hi,I have been trying to deploy a 5000 seat CUPS 8.6.3 server on a UCS201M2 (fully licenced) that already has 3 x 7500 seat CUCM servers on it.The CUPS install fails every time while trying to install the database (cant remember the exact spot).As a ...
Hi all,I recieved a new Phone on our company, the phone is a Cisco IP Phone 6921, I use the Ethernet Cable to connect it to the switch, and the phone do not power up with any message, my question here, can this switch:Show ver.Cisco Internetwork Oper...
Dear NetPro gurus,One of my clients trying to register his Cisco 7945G SIP Phone over the WAN. His Cisco phone managed to show the 'text label' as well as the extension on the phone, but it keeps showing as "Registering" and never actually registere...
Hi. I need to configure route pattern in CUCM 8.0 in INDIA. Can any body tell me the route pattern for STD calls, International calls. And one thing is also what I need to configure to PRI to make outside calls. I have added the gateway to CU...
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
2 | |
1 | |
1 |
