SRTP between 2 CME boxes
Brian Meade
Level 7
Level 7
I am trying to figure out how to configure SRTP on my SIP dial-peers.  Here is my configuration.  I have SCCP phoned off of each CME box.  I only want to run SRTP between the 2 sites.
voice service voip
srtp
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
  emptycapability
sip
  bind control source-interface Vlan20
  bind media source-interface Vlan20
  subscription maximum accept 5
  registrar server expires max 600 min 60
  srtp negotiate cisco
dial-peer voice 200 voip
destination-pattern 4....
session protocol sipv2
session target ipv4:192.168.10.2
codec g711ulaw
There is a similar configration on the other box with a dial-peer pointing back to this one.  If I turn on SRTP fallback, I get RTP traffic between the two sites.  With just SRTP turned on, the call fails due Status 488 Not Acceptable Media.  Do I need to set up crypto keys at each site and somehow authenticate the boxes to eachother?
yuanwu
Hi, Brian
Please check the CME administrator guide,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeauth.html#wp1112836
Secure Cisco Unified CME does not support SIP trunks; only H.323 trunks are supported
Rgds/Randy
