SSH 8851 advanced test key commands
CARLO CALABRESE
I am able to ssh to the 8851 just find and do a 'test key soft1' command just find.
But not able to the the advanced commands like 'test key set' or serv.
Is there something I am missing?
Is there something in CUCM that I need to enable to do these commands?
I have it working for 78XX and 79XX as will as the 8831s
The ‘test key set’ or ‘serv’ commands are working on my 8841. Unfortunately, I don’t have an 8851, but I believe there shouldn’t be any difference since they all have the same firmware versions.
As far as I know, no additional settings are required on the CUCM for these commands to work.
Response Signature
Response Signature
