06-11-2013 09:48 AM - edited 03-16-2019 05:48 PM
I need to be able to upgrade/downgrade my phone firmware, without any CUCM. I've setup DCHP with option 150, and a tftp server. If I just place the contents of the Cisco firmware .zip file in my tftp directory, that should be all I need right? It'll just request the termxx.default.loads, and upgrade/downgrade as necessary? Just making sure I don't need an xml file.
Solved! Go to Solution.
06-11-2013 10:33 AM
The cnf or cnf.xml file is the one that tells the phone which FW to get, so, you do need the config files.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-11-2013 11:00 AM
Hi Bill,
You need the XMLdefault.cnf file since u need to mention the desired firmware name in this file.
U can refer the link
https://supportforums.cisco.com/docs/DOC-23730
regds,
aman
06-11-2013 10:33 AM
java
06-11-2013 11:00 AM
Hi Bill,
regds,
aman
