Standalone upgrading phone firmware
billmatthews
I need to be able to upgrade/downgrade my phone firmware, without any CUCM.  I've setup DCHP with option 150, and a tftp server.  If I just place the contents of the Cisco firmware .zip file in my tftp directory, that should be all I need right? It'll just request the termxx.default.loads, and upgrade/downgrade as necessary?  Just making sure I don't need an xml file.
2 Accepted Solutions
Jaime Valencia
The cnf or cnf.xml file is the one that tells the phone which FW to get, so, you do need the config files.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Bill,
You need the XMLdefault.cnf file since u need to mention the desired firmware name in this file.
U can refer the link
https://supportforums.cisco.com/docs/DOC-23730
regds,
aman
Jaime Valencia
java
java
Hi Bill,
regds,
aman
