04-17-2013 12:47 PM - edited 03-16-2019 04:51 PM
I have a MCS7825-H3 already got the 4 GB of RAM. Know I need to the the process to upgrade from 6.1 (4) to 8.6 (2). This is the first time I am doing this so any help will be great.
Thank you
Solved! Go to Solution.
04-17-2013 01:40 PM
Dwayne,
You can upgrade directly to 8.6 from cucm 6.1.4, you hardware is supported on CUCM8.6.2. However it is important to note this..You must install COP File ciscocm.refresh_upgrade_v1.1.cop.sgn before you upgrade to any 8.6(x) or higher release from any 8.5(x) or earlier release.
Since this is a refresh upgrade, it is service impacting. Your CUCM server will reboot and this upgrade will take a long time. You should factor this into your plans and not carry out this upgrade during normal work hours.
You should also ensure you have your licenses in place as you will need new licenses for CUCM8.6
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-19-2013 06:19 AM
Hi Dwayne,
If you check out Table 34 of the CUCM Compatibility Matrix we see that
CUCM 8.6(2) will set the device Defaults on the 7941's and 7911's to firmware
version 9-2-1.
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
We also note, that your 7941's are @ 8-5-2sr1s so they would
be good to go. But the 7911's are @ 8-3-2s so they would need an incremental
firmware upgrade prior to moving to CUCM 8.6(2) and trying to load 9-2-1
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 9.2(1) or greater, you must first upgrade your firmware to an intermediate version (8.3(3) - 8.5(2)) then upgrade to 9.2(1).
Note This section applies to the Cisco Unified IP Phone 7975G, 7971G-GE, 7970G, 7965G, 7962G, 7961G-GE, 7961G, 7945G, 7942G, 7941G-GE, 7941G, 7911G, and 7906G.
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
04-17-2013 01:40 PM
Dwayne,
04-18-2013 08:09 AM
aokanlawon,
Can you advise me on whether these firmware currently loaded on the phones will work with the CUCM8.6.2 upgrade.
7941
Phone load: SCCP 41.8-5-2SR1S
7911
Phone load: SCCP11.8-3-2S
Thank you in advance.
04-19-2013 06:19 AM
Hi Dwayne,
version 9-2-1.
Cheers!
Rob
"Talk about a dream
- Springsteen
04-19-2013 11:45 AM
Rob as usual...great answers..(+5)..How have you been?
04-19-2013 11:51 AM
Hey Deji,
All is well my friend! How bout you? Thanks for the nice
vote & right back at ya for all your superb contributions here @ CSC
Cheers!
Rob
"Talk about a dream
- Springsteen
04-19-2013 12:19 PM
Hey Guys
I should have mention it is a publisher/subscriber so I am trying to limited down time as possible.So I want to upgrade the pulisher first then the subscriber. If I upgrade the firmware on the 7911 phones to 8-5-2 before I upgrade the CUCM to 8.6.2 will the phones still work on the subscriber running (CUCM 6.1.4)?
Thank you for your useful contributions
04-19-2013 01:06 PM
Hi Dwayne,
First off, you are most welcome
Yes, Firmware 8-5-2 is fully supported on CUCM 6.1(4) so
that would be just fine.
Updated: July 16, 2009
Use these release notes with a Cisco Unified IP Phone running SCCP or SIP firmware release 8.5(2).The following table lists the Cisco Unified Communications Manager release and protocol compatibility for the Cisco Unified IP Phones.
Cheers!
Rob
"Talk about a dream
- Springsteen
