Hi everyone! I have a client who is looking to hang several analog devices off of each port in a VG224... does anyone know what the limitation is? I fear that it will not have enough ring voltage. Thanks!
I have a client who wants Caller name to be displayed when their executives call in from their cell phone. Cell providers here (Canada) sometimes don't pass the calling name. I thought that adding that contact in personal directory may help us achiev...
I'm having an issue with some 6941 phones we're deploying for some of the clients. Here is the scenario:The phones are all directly connected to an 8port PoE 3560 switch. This switch is running DHCP for the site and all workstations can get an IP w...
Hi All - Can you please clarify the below Channel ID, Do we have different channel ID for each and every channel.Setup msg from PSTNChannel ID i = 0xA18397 Preferred, Channel 23 Setup Received send from VG to PSTNApr 15 12:25:25.092: ISDN Se...
I'm running CUCM 8.6.2, and I'm unable to add a secondary DNS server to the CUCM in the CLI.When I issue the command:set network dns secondary X.X.X.XI get the message back:" *** W A R N I N G ***This will cause the system to temporarily lose...
An 8945 Extension Mobility device profile won't load line button settings when logged in on an 8941, and vice versa when an 8941 device profile is used to log onto a 8945.However, both 8945 and 8941 device profiles successfully load line button setti...
HiWe are impelementing mobility using remote destinations (no MVA). We think that most users will forget to disable mobility on their phones or via CCMUser when they are on holiday. A few questions:1. Is there a way to display the current status (ena...
Dears,As you know the caller input within the directory call handler is limited to the following options :*0No InputNo SelectionHow about If I want to press any other digit during the Directory Call Handler.How can I accomplish this ??any Idea ?
Hi,I have configured a ATA 187 with an ext 6666 and it is registered with CM, after some time my plan change and change the EXT to 6868, Now the ATA is not registering. I tried to delete ATA and add agian but same results not registered,Can anybo...
Hi,I just had an issue where CEF was pegging the CPU on one of my CUCM servers causing call delays etc. I reset the service and everything is fine, does anybody know what could cause this process to peg at all?Thanks in advance.John
What is the max. BHCA supported by CUCM Cluster & Mega ClusterThanks Sam
HiI'm planning for a CME projectRouter 2921 with CME 9.5Call Processing ISDN30 & SIPNumber of Phones 60 (7906,7945)users are divided in to two separate companies (30+30)as a requirement 30 users on DepartmentA should use ISDN for incoming/outgoing wi...
Hi all,We need to configure remotly the favorites to some endpoints registered in our CUCM (8.6).The problem is that we need to configure some endpoints with IP and the directory number in CUCM is not able to do it. We telepresence systems we use the...
I am getting these events on my CMM Cisco IOS Software, Cat6K-lc Software (wscmm-IPVOICEK9-M), Version 12.4(15)T11. does anyone know what htese events mean? Thanks, AlbertMar 24 16:04:01.658 PDT: (1/1) Framer: 0, Event: CMQ_EVENT_T1_FRMR_INFRM, In-f...
I have a Unity Connection 8.6 HA. Licenses are installed and look fine from where you import however if you use the Tools Task Management and use Check system configuration I get the following error Any ideas
Subject | Author | Posted |
03-21-2025 03:46 PM | ||
03-21-2025 01:42 PM | ||
03-20-2025 05:12 AM | ||
03-19-2025 06:53 AM | ||
03-18-2025 05:41 AM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
