Stopping CAPF om CUCM 9.1, what consequences?
tony loktu
I have a customer that have two CUCM clusters, both running 9.1.1 (long story why it ended up so).
One cluster have not enabled "Cisco CTL Provider" or "Cisco Certificate Authority Proxy Function" and the other have not. Why its like this i don't know.
The one cluster where both of these services are enable we have started to get warnings about "capf certificate is about to expire".
Both clusters are working fine.
We don't use Sip Secure and most (almost every) device uses SCCP.
What would happen if disable  "Cisco CTL Provider" and "Cisco Certificate Authority Proxy Function"?
Hi Tony,
Please chck under System > Clusterwide parameters on cucm admin page
This parameter indicates the security mode of the cluster. A value of 0 indicates Non Secure (phones will register in non-secure mode [no security]); 1 indicates Mixed (the cluster allows the registration of both secure devices and non-secure devices).
If the value is 0, then it should be okay as per what you see on the IP phones.
Manish
6 Replies 6
Manish Gogna
Hi Tony,
CAPF works in tandem with CTL as explained in detail here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/10_0_1/secugd/CUCM_BK_C68276B4_00_cucm-security-guide-100/CUCM_BK_C68276B4_00_cucm-security-guide-100_chapter_01010.html#CUCM_TP_CBFA1090_00
You don't need these services if the server is not running in secure or mixed-mode.
Manish
- Do rate helpful posts -
Hi Manish
Just to be sure:
I have located all the phones and every device has LSC status "none" or nothing in the "CAPF Auth String" colom.
Does that mean i don't have a single device depending on CTL or CAPF?
/Tony
Hi Tony,
Manish
Hi Manish In Enterprise Parameters Configuration - Security Parameters, I find that
Security Parameters
Cluster Security Mode Required Field
LBM Security Mode Required Field
Insecure
CAPF Phone Port Required Field
3804
CAPF Operation Expires in (days) Required Field
Enable Caching Required Field
False
I can safely stop those services?
/Tony
Hi Tony,
Yes. As Manish mentioned, if your Cluster Security Mode is 0, then you can safely stop the CAPF service because your cluster is non-secure and does not need this service to be active.
Rajan
Hi Rajan
I have stopped the services and nothing happend. Thats good news.
The alarm about an expiering certificat still pops up in prime though.
/Tony
