07-10-2012 11:22 PM - edited 03-16-2019 12:07 PM
Hi All
I have CUCM 8.6 installed in cluster environment ( one PUB and one SUB). The issue is if we change any phone extension number or name or anything on Cucm PUB and assign PUB IP as tftp to IP Phone it work properly but when i assign SUB IP as a tftp it will not take new configuration work on old extension or name.
I contact cisco License team and upload new node license and restart all the services but nothing happen.
Secondly if i delete the ip phone from cucm cluster and delete the extension also from cluster. IP Phone register and work with old profile.
NO srst, no trace on cucm about IP Phone.
Kindly help in this to sort out the issue asap.
Thank you
07-11-2012 01:15 AM
Kindly any one help me in this issue, it so strange and i need urgent help from any one..
07-11-2012 01:47 AM
Muhammed,
The first step in troubleshooting database issue is to check the status of replication.
You can use :
Cisco Unified Reporting - Database Status Report
Choose "Cisco Unified Reporting" from the Navigation dropdown in the upper right corner of
the CCMAdministration page. Then choose "Database Status Report", and generate a new
report.
Or use RTMT,
In RTMT, Choose CallManager->Service->Database Summary
Please let me know what state your database replication is. The values that you will see will be either 2, 3, or 4 on each server. If replication is good, then you should see 2. with two servers you will see a total value of 4 on RTMT
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
07-11-2012 01:56 AM
Muhammad,
From the cli of the pub, can you run the following command
utils dbreplication runtimestate and attach it to the notes.
Niket
07-13-2012 01:28 PM
HI
i did 3 times up till now subscriber installation and on PUB CM group in default profile it showed me both PUB and SUB IP's but on SUB CM group default profile it showed only PUB IP.
Also i did the utils dbreplication runtimestate and get the below response....
_____________________________________________________________________________________________________
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: BROADCAST SYNC Completed on 2 servers at: 2012-07-11-17-15
Last Sync Result: SYNC COMPLETED 0 tables sync'ed out of 541
Sync Errors: 1 Errors or failures were found
Use this command to see the output - file view activelog /cm/trace/dbl/2012_07_11_17_15_38_dbl_repl_cdr_Broadcast.log
DB Version: ccm8_6_1_20000_1
Number of replicated tables: 541
Cluster Detailed View from PUB (2 Servers):
PING REPLICATION REPL. DBver& REPL. REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) RPC? STATUS QUEUE TABLES LOOP? (RTMT) & details
PUB 192.168.10.50 0.039 Yes Connected 0 match Yes (2) PUB Setup Completed
SUB 192.168.20.51 10.0 Yes Off-Line N/A match N/A (4) Setup Completed
admin:
thank u
07-14-2012 11:44 PM
Definitely a broken replication.
check this out
https://supportforums.cisco.com/docs/DOC-13672#comment-8099
Hope this helps
Niket
Kindly rate useful posts..
07-15-2012 12:23 AM
Hi nikshah
Thank for the reply...... its really help full.
I have one more question that
I want to design CUCM 8.6 in Active/Active scenario. Like i have two sites A(PUB) and B(SUB). Site A IP Phones should register with PUB( Site A tftp) and Site B IP Phones should register with SUB( SIte B tftp).
And also bothe should be redundant to each other.
Thank You
Thank You
07-15-2012 06:42 AM
Muhammad,
You can use cucm group and device pool to achieve this..
Create 2 cucm groups, e.g cucm_group_A (pub, sub) and cucm_group_b(sub,pub)
So in group a cucm group you will have the publisher as the primary server and the subscriber as the secondary and in group b you will hve it the ohter way round.
You then create two device pools eg dpA and dpB. You then assign the cucm groups to the device pool
finally you assign phones in site a to dpA and phones in site b to dpB
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
