Stuck loading CUE8.6 on ISM
Michael Durham
Level 4
Level 4
I have the following files for CUE 8.6 for the ISM:
cue-installer.SPA.sme.8.6.12
cue-vm-full-k9.SPA.sme.8.6.12.prt1
cue-vm-installer-k9.SPA.sme.8.6.12.prt1
cue-vm-k9.SPA.sme.8.6.12.key
cue-vm-k9.SPA.sme.8.6.12.pkg
cue-vm-k9.SPA.sme.8.6.12.pkg.install.sre
cue-vm-k9.SPA.sme.8.6.12.pkg.install.sre.header
cue-vm-langpack.sme.8.6.12.pkg
I entered the following command: service-module ism 0/0 install url ftp://rLEhZq5W:BHavoIZM@192.168.69.61/cue-vm-k9.SPA.sme.8.6.12.pkg and some software started to install.  I did have to answer a few questions to finish the installation process.
Now I am suck at:
Please select from the following
1 Install software
2 Reload module
3 Disk cleanup
4 Install License(s)
when I enter the command service-module ism 0/0 session and I cannot get past this point.
service-module ism 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 195
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 1.0
CUE Running on ISM
Module resource information:
CPU Frequency: 1066 MHz
Memory Size: 501 MB
Disk 0 Size: 4110 MB
No install/uninstall in progress
No localstore
The above output says CUE 1.0 is installed.
What do I do next?  I do not have any CUE mailbox licenses.  I would like to get just 1 mailbox license if I can as I only need one mailbox on this system.
I have an FTP and an TFTP server set up.  All of the files are also loaded onto the router (3925) and setup with the tftp-server command
0 Replies 0
