12-30-2019 05:57 AM
We have two new CP-8821's that need to get a factory reset. The problem is that the reset will not be accepted. Is there another way than true the menu or # + power and then 1 2 3 …
12-30-2019 05:59 AM
try below post to reset (or please confirm is the same one you did before , which failed, so we can look other options )
https://community.cisco.com/t5/ip-telephony-and-phones/factory-reset-8821/m-p/3078540
12-30-2019 06:13 AM
Yes, I tried that several times on both phones but no luck. Also tried settings>Admin settings>Reset settings> All settings.
12-30-2019 06:22 AM
as per my past experience that should work.
12-30-2019 02:10 PM
