07-13-2011 08:11 AM - edited 03-16-2019 05:55 AM
I have Publisher & Subscriber placed over WAN, but having IP from the same subnet (Same VLAN is propagted between 2 sites). Due to some requirement, i need to change the IP of Subscriber..Can i do this?? Do i need to reinstall subscriber after changing the IP address?? I am ruiing 7.1.5b SU4 with 7825-I4 MCS....
07-13-2011 08:24 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/ipchange/ipchg712.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-13-2011 08:34 AM
if you follow the document it will be fine, do not be tempted to skip some steps or reboots! they are not reboots just fo rthe sake of reboots!
Don't do this on 8.5 you will get BIG problems
07-13-2011 08:46 AM
What document are you referring to??
Partha
07-13-2011 08:53 AM
the one posted by javalenc in the previous post
