switchport on 8841 phone
k. cheng
My understanding is the phone swport cannot be managed. But if it’s bad, it can prevent a pc from getting an ip address right? my company uses the 8841.
M02@rt37
Hello @k. cheng,
You mean switchport voice vlan ?
The switch port provides connectivity for both the VoIP phone and the PC, often using a technique called VLAN trunking. If the VLAN configuration is incorrect or if the switch port is experiencing issues, it can disrupt connectivity for both the phone and the PC, affecting IP address assignment and network access.
Best regards
balaji.bandi
Sure that is Limitation Most of the deployments. if your environment have voice and Data in single port (PC connected to Phone).
BB
k. cheng
sorry. i meant the switchport in the back of desk phones, like the 8841. i was hoping for more info about them.
