10-11-2016 05:13 AM - edited 03-17-2019 08:19 AM
How to set-up sx-20 sx-80 for audio conference I have assign audio dedicated numbers to both devices
10-11-2016 08:55 AM
You'll have to explain a lot more of your environment and what you have to work with to get an answer.
10-11-2016 09:44 AM
10-11-2016 10:37 AM
You would only be able to use the CFB in CUCM if someone conferences you, or dial a meet-me. If that's all you have, I don't see anything to make a video conference.
10-11-2016 10:52 AM
I can make video conference IPv4 is active 53.67.64.97 is my IP I want to activate IPv6 sip proxy I have a dedicated number assign to SX20 12017303545 I cant seem to activate the Sip proxy to use the Cisco as a audio conference device
H323:
Status : registered
Gatekeeper : 53.29.231.155
Sip Proxy 1
Status : inactive
Proxy -
The Voice IP: 12017303545 - 53.29.234.22
10-11-2016 11:32 AM
Voip Cisco call manager 10.5.2.
10-11-2016 12:39 PM
Refer to the Administering TelePresence Endpoints on CUCM section in the SX Series Maintain and Operate Guides on how to register the SX20 and SX80 to CUCM. Note H323 will be disabled as it is not supported when endpoints are registered to CUCM, as it's SIP only.
