We have an SX80 that we are going to register to the Spark Cloud. However we also have some H323 endpoints that want to dial the SX80 directly. Will they be able to dial to SX80 with H323 by ip address if we have a static NAT setup for the SX80? Can the SX80 ip dial and use H323 at the same time it is on the Spark Cloud? Thanks
I believe H323 is disabled when registered to the Spark Cloud and I don't believe you can enable it either.
Justin
Thank you, Justin Ferello Technical Support Specialist, ScanSource KBZ
