12-02-2015 03:00 PM - edited 03-17-2019 05:05 AM
%SIP-3-INTERNAL: TCP_SOCKET_SEND_BLOCKED: connid= 1073, local_addr=, remote_addr=10.112.0.135, remote_port=5060 - All retries are exhausted, deleting pending messages
Has anyone ever seen this specific error before in syslog? I couldn't find anything related to it while searching.
Version is 15.4(3)M4
12-02-2015 08:10 PM
Hi Jay,
This error is related to the following bug
https://tools.cisco.com/bugsearch/bug/CSCuu89938/?reffering_site=dumpcr
12-03-2015 08:32 AM
Thanks Manish.
Yeah I figured it was something of that nature. I believe the alert is actually legit tho probably why it is showing in this version.
02-19-2016 09:38 AM
This same error was triggered on one of my routers by having a misconfigured Inbound Calls-Calling Search Space in the CUCM SIP Trunk Configuration. The Calling Search Space was corrected and the error went away. Inbound call functionality was restored.
05-10-2018 10:43 AM
What solution did they give to this problem, the same thing happens to me now but with an ISR 4331 that I have installed in a remote site registered by SIP TRUNK to the CUCM at the headquarters.
I hope your valuable support
06-03-2021 11:14 PM
Hi ,
I also had a similar problem, what I did is I have removed the Keep-Alive command from the Dial-peer post that this issue was resolved.
12-03-2021 10:39 AM
I’m having same issue. Still no fix?
12-04-2021 06:44 PM
04-24-2023 10:05 AM
Do you remember what firewall issue was?
07-12-2025 11:52 PM
i have the same issue:
%SIP-3-INTERNAL: TCP_SOCKET_SEND_BLOCKED: connid=8, local_addr=, remote_addr=X.X.X.X, remote_port=41371 - All retries are exhausted, deleting pending messages.
Restarting the voice gateway resolved my issue.
