Dear everybody,
According to Cisco DSP calculator, I'm able to assign "Voice Codec numbers" to T1/E1 cards
But in voice gateway, how do I know/define the T1 is using the Low, medium or high complexity in config file?
is it refer to the voice codec that has applied to dial-peer voice voip ?
if I have voice class define as follow, will the DSP change to medium complexity ?
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
dial-peer voice 102 voip
destination-pattern 10..
session target ipv4:10.10.10.1
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
or define in the voice-card ?
voice-card 0
codec complexity medium
Sam
