11-19-2012 09:00 PM - edited 03-16-2019 02:16 PM
My ITSP only supports G711 Pass-Through for faxing. I want to experiment with T38 internally. Can I implement T38 on the inside of my network by applying it to the dial-peer going to my CUCM, and keep pass-through on the dial-peer going to my ITSP? I can't find anything saying that T38 has to be carried all the way through or it can be changed at a certain hop. Any help is appreciated. Thanks!
Solved! Go to Solution.
12-01-2012 05:27 AM
Correct assuming you configure a fallback option on the gateway/CUBE.
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
Please remember to rate helpful responses and identify helpful or correct answers.
11-19-2012 10:11 PM
Robert,
The T.38 protocol is, for all intents and purposes, a codec. As I understand it there currently* isn't a transcoder or MTP that can terminate a T.38 call and replay it as a G.711 call when doing IP to IP calls. Thus the answer is, currently*, no.
-Steven
* Currently = IOS 15.1(4)M5
11-20-2012 12:00 AM
OK, so more than likely if I sent T38 towards the internal side, the end fax machine will just utilize pass through because there won't be a terminating device/gateway accepting or offering T38. I spoke to my provider and he is having the same problem. No one all the way up the line that will carry T38. Thanks for your help though.
12-01-2012 05:27 AM
voice service voip
12-03-2012 07:33 AM
Yup, thats what I did and it did exactly that. I am experimenting with Flowroute as we speak. They support T.38 throughout their network. Thanks for the tip!
04-23-2019 01:28 PM
Hi Robert,
Would you mind reaching out to me to discuss your success/failures with T.38 faxing and flowroute? We have a fax upgrade project and I'm looking at various options to move away from the traditional 1FB - analog fax machine model.
Amir
