Tapi driver that will work with Windows 7 OS and CCM v4.1
cnorton
Hi guys,
Good day! Just a quick question, is there a tapi driver that i can download which will work hand in hand with a windows 7 machine and CCM v4.1. I tried  to install the tapi v4.1 to windows 7 but its not allowing me to modify its settings, so i suspect its not compatible. I installed tapi v8.1 however its not registering to the ccm and based on event viewer, the version of the tapi is not compatible with the current version of the callmanager.
So anyone of you who experience this issue and has solution on it? We will really appreciate if someone can help us with this.
rossporubski
Level 4
Level 4
The old version TAPI will not install or function properly on Windows 7OS. The newer TAPI will not be backwards compatible with your older version CM 4.x
rossporubski
Level 4
Level 4
cnorton
Hi rossporubski,
That's what i thought as well. Just wondering if there's other way to get this worked. Thanks for your reply.
