Tar file not created error on automated backup
amarky
Dear All
I would really appreciate it if someone could help me out with this issue, so thanking you guys in advance. I have two CUCM clusters(ver 10.5) and sftp.  Both CUCM shows scheduled backup end with error " TAR FILE NOT CREATED".
If I use manual backup (without any changes) it works fine.  Can anyone tell me what seems to be the issues ?
rosaho
Level 3
Level 3
This discussion has been reposted to the IP Telephony community.
Go to Backup/Current Status in DRS and you will see a more detailed explanation of the error you are getting. Copy and paste that here (or in Google) so we can better understand what's going on.
Can you help me with the link as i didn't find the proper solution on this..
Bhanu
