03-23-2011 08:18 AM - edited 03-16-2019 04:06 AM
Due to some issues with our license we were given a temp 3 month node license to activate 3 nodes in our 5 node cluster. We have now received and loaded the correct permanent licenses, but the temp license is still in use and we have a total of 7 units authorized.
What will happen once the temp licenses run out? Will the extra licenses automatically be used or will I need to delete the temp license now and restart the ccm servcie to ensure the permanent licenses are used.
Andries
Solved! Go to Solution.
03-23-2011 10:59 AM
There is no need to do anything , the license units will just dropped , the only adding a SW feature license is required for restart.
Amer
03-23-2011 10:59 AM
Amer
05-17-2011 06:53 AM
Just to add to this. Ihave
just added a permenenant lic over a temp one. Is there a way
of checking which lic files are applicable to the running of the CUCM and which are no longer needed.
Cheers
