Testing SRST
problemchild27
                       Is there a way to test the SRST by creating any type of ACL in CUCM itself. Why am asking is, recently we faced a link flap issue, at the time the gateway was jumping between SRST & MGCP.
Thank you
      PC
5 Replies 5
ronpatel
Level 8
Level 8
You can not create ACL in CUCM. To test SRST you can stop CM service on CUCM and ip phones will fall to SRST. Also you can have ACL configured on branch router to test.
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
     Thanks for the response. If i stop the CM service, wont it affect the other branch MGCP gateway & HQ??? Did you mean i can have the ACL configured in the branch MGCP gateway itself???
Thank You
      PC
Hi PC,
Yes you can have ACL in branch router to stop SCCP signaing traffic on outgoing WAN interface.
Ronak Patel
jonathan.dixon
I usually add a null route or routes on the branch WAN router, eg:
ip route 255.255.255.255 Null0
This will black hole any traffic destined for the CUCM(s).
Bruno Rangel
In add the others comments to MGCP dont forget to TCP 2428, otherwise your phones will go into SRST mode but your gateway will not.
This the ACL you can use to test SRST:
ip access-list extended DENY_VoIPtrafic
deny   tcp any eq 2000 any
deny   tcp any eq 2428 any
deny   udp any eq 2427 any
permit tcp any any
permit udp any any
Please remember to rate helpful  responses and identify helpful or correct answers
Cheers
Bruno Rangel
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
