02-05-2024 11:47 AM - edited 02-05-2024 11:48 AM
Hello ,
Following Bug CSCwd64245
I Try to Install in CUCM patch : ciscocm.v1_java_deserial-CSCwd64245.cop.sha512
But I got error :"The selected file is not valid.please ensure that cop\ISO is
intended for this release "
My version is 12.5.1.12900
any idea?
Solved! Go to Solution.
02-05-2024 08:46 PM - edited 02-05-2024 08:48 PM
Please also make sure you have installed this on your cucm ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn.
https://software.cisco.com/download/home/286322286/type/286319173/release/COP-Files
This woud enable the installation on Sha 512 encrypted files
Carlo
02-05-2024 10:24 PM
I managed to install patch after installing the following file: ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn.
I couldn't understand whether the bug only applies to certain versions 12.0(1.10000.10) 12.5(1.10000.22) 14.0(1.10000.20)
or Any 12.5(1) release lower than 12.5.1.18900-40 ?
02-09-2024 08:19 AM
I would go by the security advisory that shows:
First Fixed Release
11.5 Migrate to a fixed release
12.5(1)SU8 or
14SU3 or
15 not vulnerablie
