ā02-05-2024 11:47 AM - edited ā02-05-2024 11:48 AM
Hello ,
Following Bug CSCwd64245
I Try to Install in CUCM patch : ciscocm.v1_java_deserial-CSCwd64245.cop.sha512
But I got error :"The selected file is not valid.please ensure that cop\ISO is
intended for this release "
My version is 12.5.1.12900
any idea?
Solved! Go to Solution.
ā02-05-2024 08:46 PM - edited ā02-05-2024 08:48 PM
Please also make sure you have installed this on your cucm ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn.
https://software.cisco.com/download/home/286322286/type/286319173/release/COP-Files
This woud enable the installation on Sha 512 encrypted files
Carlo
ā02-05-2024 12:46 PM - edited ā02-05-2024 12:54 PM
Per the bug note your version of CM is not affected by this defect.
ā02-05-2024 04:32 PM - edited ā02-05-2024 04:32 PM
Roger,
The cop file's Readme states:
This COP file, ciscocm.v1_java_deserialCSCwd64245.cop.sha512 is only designed for the following products and versions:
Any 12.5(1) release lower than 12.5.1.18900-40
Any 14 release lower than 14.0.1.13900-155
I also had a TAC engineer guide me to this cop file for my servers running 12.5(1)SU4. Do you have different information?
ā02-05-2024 08:23 PM - edited ā02-05-2024 08:28 PM
If you used the web Gui to install that patch it would fail. It should be installed through CLI
Can you please post the output of a show version active?
Please let us know
Carlo
ā02-05-2024 09:50 PM - edited ā02-06-2024 04:59 AM
No I donāt, I referred to the information in the bug note. If the readme has other information than that itās not very good as it would cause much confusion, just as in your case. I would recommend you to use the option to post feedback on the bug note and state that the list of affected versions are incorrect/incomplete. I just did that, but if there are more feedbacks on this it has a bigger impact.
That said I would go on the information in the readme file. As @Carlo Poggiarelli wrote can you please share the output for show version active so that we can verify that you have installed any pre-requisite file(s). Especially the COP file for the signature update from 2021 is crucial to be able to install any new installation as pretty much any update released now requires this.
ā02-22-2024 11:47 PM
This bug affects all CUCM 12.5 versions before SU8 as well as all CUCM 14 versions before SU3
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-cucm-rce-bWNzQcUm
Gerry
ā02-05-2024 12:47 PM
ā02-05-2024 12:49 PM - edited ā02-06-2024 04:14 AM
Based on the bug note that version is not affected by the defect either.
ā02-06-2024 04:07 AM - edited ā02-06-2024 04:08 AM
Hello Roger,
Thanks for your information. I have random answers with different TACs; One of the TAC engineer says my version is affected and 2nd says no. I have following CUCM version. Do you think this is impacted?
System version: 12.5.1.16900-48
Also do we need to restart CUCM node and phone while installing this cop?
ā02-06-2024 04:15 AM
Based on the readme for the COP file that version would be affected. See the OPs response to me. What is required after the install would be stated in the readme file.
ā02-06-2024 04:19 AM
This is what is stated in the readme file for the effect at installation.
ā05-13-2024 08:39 PM
The GUI correction has been used and the patch update cannot be stopped. Is there a way to solve it?
ā05-13-2024 08:41 PM
ā05-13-2024 09:55 PM - edited ā05-13-2024 09:59 PM
As the installation fails on the first attempt, due to that you did it from the webUI even if it is clearly stated in the readme that you should not use that to do the installation, youāll need to cancel the installation before you try to run it again on a second attempt from CLI. You do this with the utils system upgrade cancel command.
ā02-05-2024 12:56 PM - edited ā02-05-2024 12:57 PM
The affected release is 12.5(1)
UCSInstall_UCOS_12.5.1.10000-22.sgn.iso
