third party sip phone one way aduio when calling cisco IP phone
capgarr
I am having a issue when adding a GrandSteam WIFI cordless phone. I am able to register the device and talk fine when calling another Grandstream Phone or Analog phone. my issue is when talking with an Cisco IP phone "all internally" i get one way audio. this is the only issue. i can make outside calls just fine. I have attached some logs i was able to retrieve.
I notice a port issue when viewing the logs. The default port for the grandstream phone is 5060
The security profile also has port 5060.
any assistance on this would be great.
Thank you.
5 Replies 5
Leo Laohoo
One-way voice is usually an indicator that NAT is enabled and configured incorrectly.
Check for SIP inspection if you have a firewall in between?
Check the routing between the endpoint IP addresses in both directions?
Are you having issues with both inbound and outbound calls to the Cisco IP phone? which party is unable to hear the voice?
capgarr
The CIsco IP Phone can not hear the Grandstream Sip Phone. but works fine with everything else.  outside calls, internal calls to analogs phones, and to another grandstream sip phone. only issue is between the Cisco IP phone and Grandstream Sip Phone.
capgarr
the attached are the following
the issue is only when talking to an Cisco 7811 one way audio
it works fine when talking to a cisco 6901 "internal" , analog phone "Internal" and outside call's.
when calling a Cisco 7811, The cisco 7811 can not hear me talking but i can hear them fine.
it is working perfect on all other phones.
capgarr
Frame 16: 1272 bytes on wire (10176 bits), 1272 bytes captured (10176 bits)
Encapsulation type: Ethernet (1)
Arrival Time: Jan 25, 2015 00:47:14.560654000 Central Standard Time
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1422168434.560654000 seconds
[Time delta from previous captured frame: 0.153156000 seconds]
[Time delta from previous displayed frame: 0.153156000 seconds]
[Time since reference or first frame: 4.249356000 seconds]
Frame Number: 16
Frame Length: 1272 bytes (10176 bits)
Capture Length: 1272 bytes (10176 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:udp:sip:sdp]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: VMware_fc:5c:9a (00:0c:29:fc:5c:9a), Dst: Grandstr_65:64:38 (c0:74:ad:65:64:38)
Destination: Grandstr_65:64:38 (c0:74:ad:65:64:38)
Address: Grandstr_65:64:38 (c0:74:ad:65:64:38)
.... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
.... ...0 .... .... .... .... = IG bit: Individual address (unicast)
Source: VMware_fc:5c:9a (00:0c:29:fc:5c:9a)
Address: VMware_fc:5c:9a (00:0c:29:fc:5c:9a)
Type: IPv4 (0x0800)
Internet Protocol Version 4, Src: 10.70.157.20, Dst: 10.70.157.83
0100 .... = Version: 4
.... 0101 = Header Length: 20 bytes (5)
Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
0000 00.. = Differentiated Services Codepoint: Default (0)
.... ..00 = Explicit Congestion Notification: Not ECN-Capable Transport (0)
Total Length: 1258
Identification: 0xe517 (58647)
Flags: 0x40, Don't fragment
0... .... = Reserved bit: Not set
.1.. .... = Don't fragment: Set
..0. .... = More fragments: Not set
Fragment Offset: 0
Time to Live: 64
Protocol: UDP (17)
Header Checksum: 0x01f8 [validation disabled]
[Header checksum status: Unverified]
Source Address: 10.70.157.20
Destination Address: 10.70.157.83
User Datagram Protocol, Src Port: 5060, Dst Port: 5060
Source Port: 5060
Destination Port: 5060
Length: 1238
Checksum: 0x96da [unverified]
[Checksum Status: Unverified]
[Stream index: 0]
[Timestamps]
[Time since first frame: 0.000000000 seconds]
[Time since previous frame: 0.000000000 seconds]
UDP payload (1230 bytes)
Session Initiation Protocol (INVITE)
Request-Line: INVITE sip:136@10.70.157.83:5060 SIP/2.0
Method: INVITE
Request-URI: sip:136@10.70.157.83:5060
[Resent Packet: False]
Message Header
Via: SIP/2.0/UDP 10.70.157.20:5060;branch=z9hG4bK98d954665be2a
Transport: UDP
Sent-by Address: 10.70.157.20
Sent-by port: 5060
Branch: z9hG4bK98d954665be2a
From: "Network Server Rm" <sip:305@10.70.157.20>;tag=11513195~9f8e26cf-dd1a-4f43-a760-2bf850656f50-44656896
SIP from display info: "Network Server Rm"
SIP from address: sip:305@10.70.157.20
SIP from tag: 11513195~9f8e26cf-dd1a-4f43-a760-2bf850656f50-44656896
To: <sip:136@10.70.157.20>
SIP to address: sip:136@10.70.157.20
Date: Thu, 05 May 2022 18:24:24 GMT
Call-ID: 95ac0180-1ed1eaa3-73b1b-149d460a@10.70.157.20
[Generated Call-ID: 95ac0180-1ed1eaa3-73b1b-149d460a@10.70.157.20]
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM12.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Sequence Number: 101
Method: INVITE
Expires: 180
Allow-Events: presence, kpml
Send-Info: conference, x-cisco-conference
[Expert Info (Note/Undecoded): Unrecognised SIP header (send-info)]
[Unrecognised SIP header (send-info)]
[Severity level: Note]
[Group: Undecoded]
Alert-Info: <file://Bellcore-dr1/>
Session-ID: 59ab7f6000105000a000f01d2d56f1c3;remote=00000000000000000000000000000000
local-uuid: 59ab7f60-0010-5000-a000-f01d2d56f1c3
remote-uuid: 00000000-0000-0000-0000-000000000000
Remote-Party-ID: "Network Server Rm" <sip:305@10.70.157.20;x-cisco-callback-number=305>;party=calling;screen=yes;privacy=off
[Expert Info (Note/Undecoded): Unrecognised SIP header (remote-party-id)]
[Unrecognised SIP header (remote-party-id)]
[Group: Undecoded]
Contact: <sip:305@10.70.157.20:5060>;+u.sip!devicename.ccm.cisco.com="SEPF01D2D56F1C3"
Contact URI: sip:305@10.70.157.20:5060
Contact URI User Part: 305
Contact URI Host Part: 10.70.157.20
Contact URI Host Port: 5060
Contact parameter: +u.sip!devicename.ccm.cisco.com="SEPF01D2D56F1C3"\r\n
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 204
Message Body
Session Description Protocol
Session Description Protocol Version (v): 0
Owner/Creator, Session Id (o): CiscoSystemsCCM-SIP 11513195 1 IN IP4 10.70.157.20
Owner Username: CiscoSystemsCCM-SIP
Session ID: 11513195
Session Version: 1
Owner Network Type: IN
Owner Address Type: IP4
Owner Address: 10.70.157.20
Session Name (s): SIP Call
Connection Information (c): IN IP4 10.70.157.19
Connection Network Type: IN
Connection Address Type: IP4
Connection Address: 10.70.157.19
Time Description, active time (t): 0 0
Session Start Time: 0
Session Stop Time: 0
Media Description, name and address (m): audio 31428 RTP/AVP 0 101
Media Type: audio
Media Port: 31428
Media Protocol: RTP/AVP
Media Format: ITU-T G.711 PCMU
Media Format: DynamicRTP-Type-101
Media Attribute (a): rtpmap:0 PCMU/8000
Media Attribute Fieldname: rtpmap
Media Format: 0
MIME Type: PCMU
Sample Rate: 8000
Media Attribute (a): rtpmap:101 telephone-event/8000
Media Format: 101
MIME Type: telephone-event
Sample Rate: 8000
Media Attribute (a): fmtp:101 0-15
Media Attribute Fieldname: fmtp
Media Format: 101 [telephone-event]
Media format specific parameters: 0-15
