Time Adjusting for Cisco Unity Express
Hi all,
Does anybody can help me to set the correct time in a CUE ? Users get into their VoiceMail and the hour shown is different from the current time. I have
no seen any CLI command to set the correct time inside CLOCK command, neither of CUE's WEB page. I already set the Time Zone and NTP server and
hour does not change.
Thanks in advance.
clileikis
Level 7
Level 7
Hi there,
Sounds like the timezone isn't set correctly on the CUE module.  Also, see the following incase you're using a UC500:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu36827
HTH,
Chris
clileikis
Level 7
Level 7
Hi there,
HTH,
Chris
