CUCM T1 CAS into an Adtran
CARLO CALABRESE
I have CUCM 7.1.5 and i have an adtran 850. i have connected the 850 via T1 CAS connection to a 2811 running mgcp.
I get calls inbound and out just fine. The only problem i have is that the calls show a call ID of unknown.
Is there a way to add an extention number to the port?
linuxchild
are these checked under the port
6 Replies 6
linuxchild
Thats on a PRI connection, this is a CAS so the ports are EandM
T1 CAS does not support outbound DNIS.
If you want it, and mnay more features, get T1 PRI instead.
Or you can ask telco to display a same number for all the calling extensions.
I was trying to connect this site without upgrading the key system.
Thanks.
Possibly it will be less expensive, and more feature rich, to just install IP phones at the site, and then use the T1 capacity for voice and between offices.
CARLO CALABRESE
I found a way around it. I created a new partition and calling search space. I then created a translation pattern of @ and added the calling id for the system in that.
I have 20 sites like this so putting ip phones is not an option and it would cost to much to upgrade the systems to PRI.
