time based redirection to external Number
entireerfurt
i added a translation pattern on CCM6.01 for a specific extension based on offwork hours. This pattern should call an external Number.
The internal Extension 99 are translated from .99 to external Number on called party transformation and discard predot digits. It does'nt work.
How should the pattern formed to fulfill this issue.
regards
Ronny
8 Replies 8
Jaime Valencia
TP = DN you want to re-route
called party = external phone number as you would dial it from the phone
CSS = one that can reach the PSTN thru your route patterns
how do you have this configured??
javalenc
if this helps, please rate
java
TP = DN (99)
called Party = 0 for PSTN-Access + external Number
CSS = All_Allowed
But i'm not sure about the Route Pattern. I created a Partitiion, workhours_only, but the call does'nt start at this time to outside.
If i choose a Partition without restrictions, then the call will start.
regards
Ronny
then i would check the TOD configuration and make sure the translation pattern becomes active when it should
javalenc
java
i have just 2 time configs:
Workdays 8 am to 8 pm and
other times and weekend.
How can i test the partition config at another way then the TP?
regards
Ronny
use DNA to test the config
javalenc
java
But i can test dialout Numbers. i Want to test incoming Numbers from Gateway.
regards
Ronny
select the GW as the call source
javalenc
java
OK, It seems a offset to the system time to exist, bute i cannot resolve this actually.
Some Patitions doe'snt work.
Any Ideas?
ciao
Ronny
