09-13-2011 06:29 AM - edited 03-16-2019 06:57 AM
Hi Friends !!!
Hope you can give a hand on it.
problem description
ccm version : 8.0.3.2000-2
2 nodes in the cluster
phone is in the EST timezone, and all the phones are showing a lag of 12 minutes, from the exact time on all the phones.
Action plan thought by me :
SSH login into the publisher : output for the following commands :
utils ntp status
utils ntp config
utils ntp restart
Should i take other actions as well to synchronize the time and have the phones get the correct time on them.
Solved! Go to Solution.
09-13-2011 08:45 AM
Hi Aaron,
Thanks for the response , let me do it in the next 10-20 minutes and would let you know, asap.
09-13-2011 09:05 AM
in the meanwhile as discussed earlier, and probably one i had used earlier sometime as well, is there a specific command for the resynchronization of the ntp server from the cli.
09-13-2011 09:12 AM
Just 'utils ntp restart'.
It shouldn't be necessary to restart it; the whole point of NTP is that it continuously synchronises.
If the CCM system time drifts, then it's likely that either the CCM has no NTP server configured, the NTP server has incorrect time, or there is no reachability to the NTP server from the publisher.
Aaron
09-14-2011 12:30 AM
Hi Aaron,
Due to some live hours was not able to give an update, we have planned a TFTP service restart to see it solves the issue as well as i would get the necessary ntp status from the subscriber as well.
09-14-2011 12:33 AM
i just wanted to clear my thoughts on the following, which i have done earlier as well, but the new organization guys are adamant in not accepting it >>> does Restarting the TFTP service during production hours, would cause the calls to drop immidiately, and in case it does ( if et al ) then it would not be more than a few minutes, if i am not wrong ?
09-14-2011 12:44 AM
TFTP just serves configuration to the phones. If a phone is restarting during the restart of TFTP, it may not get it's TFTP config file on the first attempt. If this happens it will retry.
No call impact will occur.
Aaron
09-15-2011 02:30 AM
Hi Aaron,
we got it working as the local time ( as you mentioned) was wrong in the IST zone, a lag of 14 minutes, we changed it from the OS admin on the call manager and finally from the CLI reset the timezone, moving on forward, restarted the cluster, and bingo.. it worked !!!!!
Once again thanks for guidance
Abhishek Singh
09-15-2011 05:56 AM
Hi Abhishek
Great work!!
Tapan
09-15-2011 09:34 AM
Hey...
Great to see you on the support forum.
09-15-2011 09:00 AM
No problem!
If it helps, please rate it!
10-04-2023 01:45 AM
Hi Singh,
It seems i have the same problem as yours , i have a time lag of 8 minutes. i have done all the steps mentioned earlier and the issue still occurs . can you please provide the steps taken when you solved your issue ? it might work for me as well.
regards,
kasem klot
