Does someone is aware if Cisco board can be configure to support lldp (instead of CDP)?
Hi all,I would like to inquire if there are any release notes for Cisco Jabber version 14.0 that mention a bug related to intermittent disconnections experienced by agents. After upgrading to version 14.3, the issue was resolved. Could anyone confirm...
Hi, our client needs to open the recording notification tone when their clients call the phone, but they need to customize this tone, according to the law, they must use the legal lauguage to remind their clients. so do you know how to custom this r...
Hello,Like most people, we continue seeing a major influx of work from home staff, and all the CUCM work that needs to be done so they can access Jabber on cell phones, home pc's ect.... Where can I find some documentation on how to script the creati...
We're having some problems with our backups over SFTP and also when trying to upload files to servers. We have 1 CUCM Publisher with 3 subscribers, 2 Unity Connection servers and 2 IM and Prescence servers. Currently running 10.5.2.11900-3 For the mo...
Hello community i am facing a strange problem that i didn't find an answer on it. the only thing i had found, that another user faced a similar situation but without got answer https://github.com/pjsip/pjproject/issues/2675 The problem when ISP send...
Using IP Phones 8800. I have accidentally pressed page all (it is where our old phone's hold was) before putting a call in park. How do I exit out of paging to get back to the call?
We're experiencing issues with the CP-7861/8800 operator phones with expansion modules. The operator receives incoming calls minimum of 5 to 6, every minutes. When they're on an active call and attempt to transfer, the notifications for incoming call...
I'm playing around with a 2951 and a few phones that I have laying around in my basement. Everything works fine with the SCCP calls, but when it comes to the SIP phones, I have outgoing call issues. The system is sending the phones' extension numbers...
Hello how i can change the all LDAP users Synched with AD to local users at once in CUCM V14
Hello,It's possible to export all directory number with the created date?
there is no CUBE between the telco and CUCM Could you provide some guidance on how to resolve this issue?* this call flow work on another telco.*Works for landline calls but not for mobile calls
Hi there,We're in the USA and have a bunch of 3pcc 8800 series phones on a hosted voip carrier. When users try to redial a number from the Recents log, the phone is automatically adding a "+" plus symbol before the leading country code (almost always...
Hello everyone, In the IP Phone CP-8861, the ring tone is generated by a built-in speaker. Is there any way to take the ring tone out, so that I can amplify the tone using external amplifier or transmit the tone via FM Modulator ? Of course there is ...
HiI have two CUCM clusters(old cluster and new cluster) with one SQL server. There is no jabber user in the old cluster and all of the users are registered in the new cluster. Chatroom feature is deployed for both IM and Presence servers and SQL serv...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM |
| User | Count |
| 5 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
